Caution - Contents May be Hot
You think thats bad?
I have a Knife that says "Caution, Sharp Blade" Written on it :eek:p
I made a thread about it awhile ago :D
Its so that they are not liable in a legal case.
The point behind this thread is that society should be in a situation whereby companies find it neccesary to indemnify themselves against legal cases from absolute morons injuring themselves through things which are blatantly obvious.
Sometimes you get a kikkat which is just chocolate.
Maybe sometimes they accidentally make food which is simply cannot be heated up.
You get all sorts of intelectual ranges nowadays, so what if other morons cant work it out, is it really killing you to have that written on there?
This is usually because most cars have common parts between left and right hand drive models. It makes very little sense for manufacturers to produce stock of any item that can be reused from the LHD model, for the tiny tiny tiny RHD market.
I initially thought this but Tefals explanation makes more sense, after all it's a sticker, not a manufactured part.
because people may not use the passenger sun visor before placing child in care, but will most likely have used the drivers one.
Also i think you can buy a banana hammock with this warning on :o
As to the warnign on beens. I don't really have a problem. It's a fact clearly stated.
Alan Partridge said:
the temperature inside this apple turnover is 1000 degrees. if i squeeze it a jet of molten bramley apple is gonna squirt out, it could go your way it could go mine. either way, one of us is going down
What's more worrying, the fact they put that label on the beans or the fact someone read the label and posted about it on an internet forum :/ .....
I opened our egg box the other day and it had allergy advice "this product contains egg!"
Well I do hope so otherwise I'd be taken them back to the shop!
Syph's missus.
