just a quickie put 360 on today the console crashed so turned off then on nothing happened green light and 3 red outer lights came on, i left the machine alone for 15 mins tried again and it is back to normal does this mean i am on borrowed time ?
Randomly, unfortunately. Anyone who tells you otherwise is speculating. If it was anything apart from random the problem would be fixed/isolated/remedied by now (you would think). There is speculation that the new editions suffer from it less (but it can't be "fixed" else they wouldn't spend a lot of money on giving everyone with new consoles 3 yr warranties).How often (and likely) do these RRODs occur? Bought my first 360 last weekend so am intrigued.. is it any less likely with a newer console?
i got the premium. bought it last july, what i will do is continue to use it until it happens again and then buy an elite send this one to be repaired then send it to the almighty bay site or even trade it through a high str chain
I bought an elite last weekend on a whim so i could have a play with hdmi to see if it was any difference over VGA, it was DOA after one hour.
The picture was worse with hdmi than it was with vga, so i just took it back for a refund, but there obviously is still some issues even with the new ones, although perhaps i was just unlucky (or lucky since it turned out there was no real point in having it).
The new consoles are so far quite reliable anyone saying otherwise is just speculating, more reliable than PS3 according to one source on here anyway, so would not worry about it at all.![]()
How can something be dead on arrival after an hour of it arriving?![]()
I mean 3rd console within 18 months isn't good.
Yep, im on my 3rd in 13 months, but my new ones a falcon so hoping its going to be better.
I was just thinking, is it related in anyway to the consloe being moved around!
