Need some Dreamweaver Help.
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi, well I am trying to make a website and well I am placing some shoes into the table, this is a college assignment and I know my website looks pretty crappy but I am not very skilled in dreamweaver and its quite hard.
Anyway I set these tables and moved the shoes in and well I cant really move them around how I want to, I need to place text under the images and when I press enter to move to the next line the table just keeps on going down and messing my table up, anyways I got an image under:
I hope you understand what I am saying, its hard to explain :). The white bit is not a problem, clicking on it gets rid.
Thanks.
Willz.
More cells? I dont know, I have to use tables I think, or it was recommended, layers seemed much easier but they move about all over so no go there.
I think he means...
A1 (shoe)
A2 (text)
A3 (shoe2)
A4 (text2)
ect.
If this is your only project making a site then you can get away using tables. But if you're on any sort of web design course, you should really be looking at using Divs and CSS.
I think he means...
A1 (shoe)
A2 (text)
A3 (shoe2)
A4 (text2)
ect.
No I'm not on a web design course I'm sure if I did one they would teach us. Whats that A1, A2 etc..?
If you want the image and the text to be in the same square/cell/td, when you hit return it'll balance out the space between the top and bottom of image in the cell. You'll need to valign/vertical align the content to the top from the properties options for each square/cell/td to stop that happening.
To add an extra row inbetween the rows, click in one of the squares/cells/tds below where you want it and hit ctrl+m.
