Whats the feeling on this board now WJA96, much improved?
As Rodney Reynolds would say "This is a KICKASS product".
well asd mentioned earlier for 225 package ram cpu n motherboard am @ 3.7 lolwith the 8200
and when i can afford some 1066 ram it will be going over the 4ghz mark
so imo JW pwns
, well done to the comapny for making an awsome board will buy 1 for future rig
and wont be ruling them out as a budget ooh that cheep so it must be nasty board. Thanks for satisfying my ocing needs and my wallet
awsome guys
ok WJA96 i locked theusb freaquancy and the pcie clock set the strap to 800 and it still wont change the dividers with the settings even tryed the other strap, still locked on 1:1 with any divider option and clocking the memory at aroun 940mhz with the chip only reaching 1.8ghz.
Could it be down to the cpu interfearing with the settings in some way as its the only thing i havnt tryed with something in its place.
What ram you guys using to get the high clocks with this board?
with my Geil ULL this gets overclocked to 927mhz so dont worry)
I have had issues with some changes not being recognised - try loading optimised defaults and restart, then apply the changes. As tanner says, set the PCIe to PLL (the next option is 100) and the SATA to PLL or Fixed.
I've had my best results with PC8500 Ballistix, but the second post has all the RAM I know to be tested and good.
but SATA should leave it as default.![]()
it should be STARTUP![]()
sets my e8400 core voltage to 1.12 default, which is fine but when i try to increase the voltage to the next level (which the bios labels it as 1.23volts), when i restart the computer, my vcore is set to 1.42 volts. If i try to set it a few notches higher, ie to 1.26volts, on restart, the bios still puts it at 1.42. So basically, i can either have my vcore at 1.12 (default) or 1.42 which is too high.
