Caporegime
- 11 Mar 2005
- Leafy Cheshire
You can hear my turbo spool, if you come off the throttle around 2.5 / 4k you can hear it dumping the air back into the intake system.
Simple solution = up the boost
Mine whistles like a good-un.
I'd think doubling the psi with be called getting carried away![]()
It prob only runs something silly like 6psi![]()
4psi.. wtf lol ! Whats the point in having a turbo to run 4psi. Phate up the boost, now !
Haha, I take it that's low?
Not a clue how to fit the valve though, and to what pipes either. If I can find some decent intructions then I'll probably do it. What sort of bhp gain would I get by doubling the psi?
Low? I had mine set at 17 for my last RR run.![]()
