Of course it won't bloody take off.
Basic physics tells you this fact.
What basic physics are those then? The sort they teach in Yorkshire?
You aren't taking off in a vacumn (you'd also need to use engines that don't require oxygen) and therefore there is still air movement.
But if the plane is not moving then the air movement is subject only to wind, and if wind could lift planes... well the industry would be in trouble
OK, so if the conveyer is only turning the wheels, but its turning them at exactly the same speed as to counter forward movement, then the plane will not be moving... How does the plane move forward if there is a conveyer moving it backwards via the wheels? While the plane is in contact with the ground the conveyer will be directly affecting its motion... it doesn't leave its wheels behind.
Wrong. It does move.The plane isn't moving.
There's no pressure difference.
There's no lift.
Plane doesn't take off.
If the thrust that is generated is countered by a conveyer belt
There's no lift.
A plane is standing on a runway that can move (some sort of band conveyer). The plane moves in one direction, while the conveyer moves in the opposite direction.
Simple answer. The conveyor does not counter the forward movement of the aircraft. It only spins the wheels.
This is the bit people can't get their head around. The conveyor belt doesn't counter the engines' thrust.
Conveyor belt pushes against wheels -> These forces are equal.
Engines push against air -> A forward-moving force is generated.
It's two independent systems.
A plane is standing on a runway that can't move. The plane moves in one direction. Can the plane take off?"
Are you the one who files 737-800's?
Forgive me if I've got the wrong person![]()
OK, let's do this another way, by re-wording the original question, removing all the bits that aren't needed to answer the question correctly.
