Well I'll be first admit that taking off on a moving conveyor belt isn't the standard operating procedure for the 737, and I'm pretty sure that boeing didn't include it as part of their testing schedule so I cannot be certain on what would happen lol
[DOD]Asprilla;11086263 said:The plane will move forward though. The engins thrust against the air, not against the ground (like a car on a rolling road) and therefore the plane will move whilst the belt will only make the wheels spin faster than they would normally.
Call me an idiot, I believe you lot when you say it will take off
I just can't get my head round how when you say its moving even though it isnt? I mean surely even if the tyres are going at silly speeds and the engines are on, if the conveyor belt is keeping it still, there isnt any air moving over the wings. Or is it that because the conveyor belt will always be playing catch up with the plane, the plane is theoretically moving, even though physically it hasnt moved an inch?
This post isnt trying to say you're wrong, I just want to try and understand but can't
Yeah but the water isn't generating motive force in the opposite direction to the plane therefore it glides forward over the top of the water and is not at a standstill I know technically the plane is moving forward however it's covering no distance therefore the wind pressure moving past the plane is not changing and so it won't be able to create the lift required!
Ahhh I see your point now
The thing you're missing (and the thing I missed at first, the first time round), is that the wheels have no effect on the speed of the plane. They're just spinning freely. So once you get that in your head, you can basically take the treadmill, the wheels, everything out of the equation.
Literally this simple - stuff comes out of the engines
that stuff pushes the plane forward
That the wheels will be spinning twice as fast is irrelevant - because the treadmill can only act on the plane's wheels, and the wheels do not affect the plane's speed
The points in bold is what just refused to sink in with me last time, once it went in I got it.
Basically, it is impossible to hold a plane stationary on a treadmill.
If the engines deliver enoug power to move the plane forward at 30mph, and the conveyor belt is moving at 30mph in the opposite direction, the wheels will spin at 60mph and the plane will still move forwards at 30mph.
it will take off but just take a lot longer to get off the ground because the wheels are spinning madly?
Shouldn't really take any longer at all, maybe a little because of the friction in the wheels. The wheels are really entirely irrelevant.
The only way the treadmill might stop it is if the grease in the wheels got too hot and the whole kit and kaboodle burst into flames, but I should hope planes are built to a better standard than that
I actually like this problem as it seperates the clever folk from the cretins.
I realised "cretins" was probably a bit harsh afterwards Still, you have to be pretty dense to figure that a plane takes off using its wheels.
