Howard was amazing, loved Green's cake blowout one though.
Nothing flash, I do that in the park every week when I play with my homies, but I grip and pose on the rim.
threw throw
I love the creativity in dunk comps.
My friends and I always tried our best, but unfortunately we're not tall enough to get enough height/time to do anything overly flash. Brings me back to singing skee-lo - "I wish"Bah, I'm touching 6'1" so I'm still happy with my efforts. It is so much easier if you're 6'6"+ end of.
I'm lucky as I've got quite big hands so palming is ok for me, but I tend to use 2 hands as I'm a 2 foot jumper it's easier, I haven't got the fluidity for a 1 foot take off, I'm more of a power forward really (15st) so I need a 2 foot take off anyway. If you get high enough palming is less of an issue, try some allez-oops? Or work on your rise and try a 2 hander. If you can get one wrist to ring level you should be able to reach with 2 hands. I find jumping is more about technique and timing - though some explosiveness helps if you manage to do some squats and calf raises as well as some power cleans.
Kobe has dunked from much further away tbh.
As has Jordan
