would you be happy if say OCUK or another retailer sent you a "used" but in sellable state say GTX or X2 if you've just forked out 280 quid ??!!
I'd be ******* annoyed.
I know a certain retailers has been known to do that.
Hang on here, im not the one that writes the sale of goods act
The 7 day grace is simply because you have no way of seeing the product or having a demonstration in the shop before you buy.
yeah - but that doesn't mean using it as well.
its not a try before you buy thing.
its a "if" you've ordered, and whillst waiting to have it delivered change your mind thing, not put it in your machine, see if you like it or not, then send back - whats the retailer supposed to do then ?
do you get to test the product if you bought it from a shop, ie *COMPETITOR*, local PC retailer etc ?
I would advise you to take a little time out and read up on this,
On a totally separate note.
For those of you who don't have the 8pin plug (myself included).
Try giving your PSU manufacturer an e-mail and ask them to see if they can send you a 6pin >> 8pin converter.
I recently e-mailed OCZ about one, 3 days later a 6-8pin converter arrives on my doorstep free of chargeCan't beat customer service like that!
Worth a go![]()
its warming up my south bridge chip.
yea the black retention clip is like a mini raditor and heats everything up in its area including the mobo, Im sorting it out by installing a PCI fan and move it to another PCIx16 slot where it cant interfere
clearly ati needs to up the fan speed ive been searching the net and have discovered the fan spins in most cases at no more than 40% of its top speed it probably just aint enough.
