New car uses more fuel in the beginning?
Is it running on E85?
FFVs experience no loss in performance when operating on E85. However, since a gallon of ethanol contains less energy than a gallon of gasoline, FFVs typically get about 20-30% fewer miles per gallon when fueled with E85.
In case you weren't aware ;)
I find, driving the mixed fleet of 3 year old or less trucks at work, that the newer ones return considerably poorer consumption than one thats already done a couple of 100,000 km, the difference is usually about 1.5mpg (which in an HGV is a lot!)
when they're only doing 8-11mpg yeah i'd say so too! :eek:
No, Euro95 as there are no E85 pumps close and the price is 50% higher.
I know about the extra fuel consumption of E85 but the advantage is that it gives more power :cool:
I bought a 1.8 Flexifuel as it was a discounted deal and cheaper than a 1.6 with a business pack as well.
No that bad really i get under 28mpg from my pug 307 2.0 thats over the last 3000 miles
I think the onboard computer is a bit confused, maybe because it takes time to get a reliable reading, today I watched the real-time fuel consumption meter on my way to work, and it was no way a 25mpg average, it was way higher than that, even with the traffic lights, almost all the way it was ~38mpg when driving 50mph and obviously when accelerating it was way higher so I doubt the average is really 25mpg.
The average even went down from 11.1L/100KM to 11.0L/100KM in 15KM so I have no idea where the high fuel consumption of the first half of the fueltank came from.
I have a new car about very 6 months and it usually takes about 2-3,000 before the mpg settles down.
Nope.
Engines are normally driven by the manufacturer for ~2-4 miles, but that is about it. Most manufacturers give recommended running/bedding in procedures in handbooks.
The mileage on my car was zero (don't know how it got out of the factory and onto transport though :confused: )
My girlfriend got a new car a few months ago and that had 6KM's when she got it.
Good point about the manual though, I will have a RTFM when I get home :p
Digital odometer? It may be that the PDI procedure starts the clock.
I *think* a lot of new cars have a facility whereby if the mileage if < (for example) 15 miles, the PDI check allows this to be reset to 0, one time only.
