ive just picked that up, going to save it over night and see if any discount or money off appear tomorrow.
how do you save it overnight? after 15mins i thought they dissapeared
which one is it, dell 355?
Auto-refreshing plugin for firefox, or something like that (at a guess)
I think people did used to do that, not sure that works anymore, i have a seperate program.
The BCM2045 is Bluetooth while the PCI device is indeed the audio. I'm using the R171789 driver. I had some trouble with this at first, like it would say some ExitError, or when I got it to reboot first during installation, it would say the device was not supported! But then I found that when you first try to install using this driver, if you have a 'Found new hardware' thing popping up, then let it scan your PC for the driver and it should find it.
That is a commonly reported thing with the XPSM1530, the reviews I saw mentioned it.And is it just me or is this laptop quite highly charged because I've had it connected to the mains non-stop for about 4-5 hours now, and I've started to get tiny static shocks from it, mainly around the keyboard area.
Ah ok, that kinda makes me feel a bit better now. I thought maybe it was to do with the AC adapter, particularly the way I plugged in one half into the brick cos it has no signs about which way you can plug it in. I tried the other way and maybe it's a coincidence but so farm less shocks!
Anyways, I'm gonna format it again tomorrow cos I mucked it up somewhere, and this time I'm gonna write down a detailed list about what files I use and what order I install them in. I spent so much time today with trial and error going through many different driver versions until I got it right, so I definitely should keep note.
Care to share the info on what files you used and the way you installed them with us please?
Should be getting mine tomorrow so over the weekend or even friday night ( at work) i'm going to format it
I'm heading to bed now as I've been up since 10am working with this laptopI'll try and compile my info by tomorrow night.
I would also like to share with you guys that I've just run 3DMark06 on mine and I got 4445 points using the 169.09 drivers. I'm glad I paid the extra £40 or so for the 8600M GT.
Mmmm . . . . just took it to the checkout, and Dell Outlet are now adding on 49+vat for delivery, which wasnt being added when i ordered last week. Gits !
R
mehul
Those of you who received their M1530 and 1330s do you guys also have the music stuttering issue?
It's getting quite ridiculous I'm getting a few stutters every 5 minutes or so![]()
