Gainward 9600GT Impressions + Benchies
1 Dec 2005
Stoke on Trent
Just got back from OcUK with a Gainward 9600GT 512Mb.
Pics :
As you can see it does have HDMI onboard along with a single DVI and TV out.
Included in the box is the card itself, driver disc, molex to pci-e power thingy, and the HDTV breakout cable.
Just going to install then i'll be back with some benchies :)
Cool... I'd be interested to see how noisey they are, as all the reviews Ive read dont say.
Also, do they have sound over the HDMI?
Will be interesting to see mate! :)
The Gainward card does look like an attractive package I do like the HDMI onboard :)
Lanz I believe Guru 3D said they were around 42dec load or something so not bad at all
Gainward look to put a lot of effort in the design of their cards which makes a change from the standard cards, i like the onboard HDMI and the cooling looks to be very good.
Right back with a few benchies. At the moment the card is at stock and my CPU @ 3.2Ghz
Ive got the figures for my 8800GT and GTX to compare against. Im also including the pair of 8600GTS cards ive just took out as a comparison as well as the 2 cards together also total 64 streams.
Crysis OcUK Benchmark :
8600GTS SLI : 23 FPS
8800GT : 42.35 FPS
8800GTX : 38.26 FPS ( strange but true )
9600GT : 30.03
So the 8800GT is quite a way ahead in this test but the 9600GT suprasses the pair of 8600GTS's
3DMark06 :
8600GTS : 9115
8800GT : 11204
8800GTX : 12006
9600GT : 9919
Pretty much the same story here.
Let me know if theres any others you want doing and i'll oblige if i have the game :)
Really must resist the tempation to get another :p
With regards to sound over HDMI, this dosent come with a pass thru cable to connect to the motherboard like the 8600 did. :)
Looks good, overclock it to the max and do Crysis benchmark again. Would you say its worth the money you spent on it?
Deffo worth the cash considering i should get bk for the 8600 cards. The card wasnt excessivly noisy either, in fact i couldnt hear it ramp up when 3d stuff kicked in :)
Do you have Oblivion mate?
If you do, could you run it with all the settings maxed at 1680x1050 and just walk around outside for a few minutes and see what average fps you get?
Ok, mild overclock to 700/2000 gives :
Only 2.62 extra FPS on crysis and about 500 pts on 3dm06. Its probably got more in it i just want to see what others get thiers up to first :)
Ive got oblivion, i'll give it a go later. Not sure if my FRAPS works with vista tho
Under that chunky heatsink enclosure, is the heatsink just the same as this one?
Similar, i tell you what it is, remember the OcUK 7900GS cards they had a while back with the big chunky black heatsinks on them? They are like those.
This was them :
