However, even though it seems taht the new 9800's on the g92 core will be basically the same as the 8800's on the g92 core.. I was wondering whether anyone has considered that the 8800gt and new gts were/are in fact testers cards used on the g92 core, for nvidia to see how well it performs and what improvements they could make.
Essentially making the 8800GT and 8800GTS prototype 9800's as it were. Because when you look at some reviews of the new 9600GT with "only" 64 stream processors, I believe that the results justify themselves.
With effectively half of the shader processing power, the 9600GT can hold itself quite well up against the "superior" 8800GT which has twice the number of shader processors.
http://www.guru3d.com/article/Videocards/501/19/
The same goes for the Crysis Single-Player demo, which isn't an excelletn example since it's the demo..but again, half the shader processors yet around 80% - 90% of the 8800GT's power..
http://www.guru3d.com/article/Videocards/501/21/ (Although I admit the 8800GT would probably open up the gap on the 9600GT at high settings and above)
World in Conflict - The similar trend continues..
http://www.guru3d.com/article/Videocards/501/23/
3DMark 05 and 06 - Not that they really matter, btu the ressults show how well the 9600GT holds up against the 8800GT..again.
http://www.guru3d.com/article/Videocards/501/24/
And also a few more benchmarks and game tests can be found there..
But the point I'm trying to make is that with the "new" 9-series cards, I believe that
Nvidia have tweaked and optimised the efficiency of the G92 core, others the 9600GT should be performing at aound half the performance of the 8800GT, but its not, it is clearly hot on its heels, so imagine what a 9800GT, GTX or GX2 might be capable of if the results from the 9600GT with only 64 shader processors are anything to go by..
Thats just my opinion anyway..
HyBrId
P.S. I'm so happy that I snapped up my two lovely BFG 8800GTS 640mb OC2's in the overclockers clearance sale a little while back, at £129 inv each they were a steal
A competitor was selling just one of these for £259 :O I have had them overclocekd upto 710/1700/2200 so far in benchmarks
Excellent OcUK
