That's not a bad score considering its with a 3GHz dual core. With a highly overclocked c2q and if the GTX itself overclocks well it could get as high as 17000 I'd say.
It was 14k with a quad at 3Ghz
That's not very good, my machine scored about that with an 8800GT and my CPU at 3GHz.It was 14k with a quad at 3Ghz![]()
Sorry, my mistake. It was 3.2GHz on the CPU but that's still not a big overclock.Oh dear your right.Yea, pretty disappointing score then.
If you game on 22" or lower then I'd go 8800GT, if on 24" then I'd get the OCUK 8800GTX or the 3870X2 if you can find a cheap one
I can tell you from experience an 8800GT is awesome for that res, even for Crysis.Running 1360x768 on HDTV. I like to use as much AA and AF as poss because of the screen being 27" and limited to 1360x768.
Both the GTX and 3870x2 are too long for my case. I'm thinking that if the 9800GTX is a rebadged GTS then buying a GTS should mean it'll last for while as it's the fastest card that'll fit in my case.
There should be a short 3870X2 out soonish, don't know the date, but i think it's roughly shorter that a 2900. There are some pics of it over on fudzilla, can't get the link though, i'm posting from my mobile
, was only a small fps difference mind. Still, getting a 3870X2 this week, and i'm really looking forward to what r700 brings.
Yep, r600 has turned into something nice with rv670 and r680, aa problem seems to have disappeared on some me the latest benches, an 8800GT had more of an fps hit than a 3870 on a recent techpowerup review, was only a small fps difference mind. Still, getting a 3870X2 this week, and i'm really looking forward to what r700 brings.
It's too tall for my case I'm afraid.
 i'm sure a 3870 would be pretty good considering the recent price drops. I'm sure it'd run crysis decently with most if not all on high.
And you just know some douche would buy these.![]()
There's a preview on techpowerup of the 9800GTX, source is expreview. Scores 14000 with a qx9xxx cpu at 3ghz, looks like it is just an overclocked gts![]()
