Western Digital RE 2500ys hard drive dilemma
24 Feb 2008
Can any one please help me; I have just purchased a Western Digital Caviar RE 2500ys RAID edition hard drive by mistake. Have checked reviews and it seems that mainly used for RAID configurations. I only want to use it as standalone drive; I have also read that it as got something (TLER) time-limited error recovery, which can cause problems on standalone set up
Can any one please advise?
Thanks
:confused:
The TLER means that if it cannot read a block of data it will give up fairly quickly unlike a standard HDD which may well spend a minute or so trying to recover the data.
At some point you may get disk errors and you may have a slightly reduced chance of recovering that particular file.
But then.. you back up anyway....... don't you
AD
Just read on the net that this further can be disabled by some software fix, if this is untrue I will return
Thank all
