I play Crysis very smoothly on all high 1680x1050, why would I need to upgrade?
I think people don't realise there are options other than "very high" in the menu and expect too much.
As an aside, I don't remember any of this drama when Oblivion came out. People just accepted that you will need more grunt to play it without all this drama and accusations of Bethesda ruining the coding, or being liars.
Oblivion came out in March 2006 and no card out could run it at high framerates maxed out, even in Crossfire IIRC. It was only when I went from an X1900XT to an 8800GTS in February of last year that I got both maxed out settings and truly smooth framerates, not one or the other. So come on people, cut the drama.
In fact I strongly suspect this is why this thread was made, easy lights the firework and watches as usual.
why you need to upgrade you got 17 k in 3dmark06 you can play fine on high
Just seems that way with you lately. You made a thread about Crysis and the CPU which turned into a flame war between the "Crysis fanboys" and the "Crytek haters", you started one the other night which got deleted, and now this which is going to turn into a flame war, guaranteed.Great post mate.
respect
Last sentance is dissapointing
but I'd be the first to apologise if I am truly wrong.
well i get 20 k + in 3dmark06 and i play crysis fine with everything on high + config hdr and etc.
*Snickers.*costumers
In fact I suspect this thread was made for easy to light the fuse and watch the action as usual.
