I assumed he would've checked all cables first.
Scotty... Boot from the live CD again. When It's up and running go into
System/Administration/Partition Manager.
(give me some leeway here, it might not be EXACTLY as I state... Partition Manager only lives on the Live CD so I cant "dummy run" it on my active system)
From within Partition Manager select the new drive or any drive you want formatting. There is an option there for what filesystem you want on it.
Select NTFS
Click APPLY
Theoretically..... Robert will be your Fathers Brother. If it does it Ok.. Then it has to be a borked windows CD
[EDIT]
Ok.. I just installed GpartEd. I believe this is the manager used by the installer. looking in my system menu its not called Partition Manager its Partition Editor
Just looky at THIS Screengrab to see what I'm piffling on about.
The NTFS option is ghosted on my screeny coz its already formatted to NTFS
Select NTFS
Click APPLY
[EDIT]
i got a new xp home cd which i borrowed from a mate and it works. Its installed and everything.
I didnt even think of that because it installed it originally fine so it must have got damaged or something.
The ide cable that connects the dvd drive to the motherboard had a small rip in it but i removed that and it still does it (i think, it restarted anyway). yeah the pc also restarts itsself automatically sometimes??
