I don't usually consider my desktop worth posting, but I'm quite pleased with this work in progress:
If any one can recommend some good dock icons that will go with the above I'd appreciate it.
Don't know if I'll ever use a different wallpaper![]()
Email in trust!time for somethig new
snip snip
what theme or more importantly dock is that ?
Is that RocketDock you're using, if so what extensions/skins have you got on it?
What theme? or have you just edited your basic XP one?
mate can ya send the linky for that WP, that looks so awesome!
Rocketdock, using my own Icons, and the stacks plugin
Oh, actually, the HDD icons are rad-e8's snowe2
theme is AMANA08![]()
