I can't figure out why my rig isn't running as it should. Even at the best of times I couldn't get more than 38fps in the crysis benchmark and something like 11-12k in 3dmark.
I installed 8.3's a few days ago and Crysis dropped to 29fps. I've done a fresh driver install, removed the old ones and used driver cleaner pro so there's no chance of it being old drivers messing things up.
Crossfire is enabled in CCC and shows as enabled in Everest (GPUZ still doesnt show it
It's currently running at -
CPU - 400fsb x 8 - 3.2Ghz
Memory - 400mhz @ 5-5-5-12
GPU's - 825/1250mhz
I know it's not a quad and it's got a low cache so I've always put it down to that but I keep being told it should still be higher, and after comparing a few scores it would seem that it really should be running better than it is.
Anyone got any ideas?
GPU's - 825/1250mhz
