Get the dension gateway 500 which works with cars fitted with I drive. You can keep you cd changer its selectable so works instead of it when you select it. It has a USB port(so you can use pen drives with music on too) as well as the ipod connection. There are loads of videos on how well it works on youtube. The BMW ipod connection is rubbish in comparission and you will loose the cd changer. The dension is only £270 as well. Im saving up for one for my car. It wont need BMW to program the car either, it just plugs in between the cd changer and car wiring loom.
http://www.ipodcarkitdirect.co.uk/i...teway_Interfaces/Dension_ice>Link_Gateway_500
Edit: this is it a Audi but it works the same with Idrive http://www.youtube.com/watch?v=k07GX7kATro.
