New N95 had been used
4 Feb 2007
Nuneaton, UK
Finally got myself an N95 8Gb, left oranage and now on O2. Got it free on £35 a month tarriff.
Got it instore yesterday, during the sign up she didnt open the box, i wasnt bothered as I already knew it was the phone I wanted. I got home, broke the seal and started using the phone, went out last night so didnt use it much, took it to work this morning, I looked at it later in the morning and noticed marks on the top, tried to wipe it off and realised it was scratched, wth? It had lots of fine scratches around the speaker opening and light sensor, then I thought infact most of the phone looked a little shabby. I couldnt understand, have I managed to ruin it in less than a day? The phone looked like it had 2 -3 months of hard use, no way I did that I thought. I finished work at 2 and went straight back to the shop with the phone boxed up. The girl in the shop tried to say it was just the finish of the plastic, she compared it to another new one and said it wasnt much different, showed it to the manager and they said they wouldnt swap it, i pointed it out more to the manager and said its clearly scratched, then she said "oh yea, I thought u meant on the top, we will change it for that" Maybe she was trying to fob me off.
The box deffinatly had a proper Nokia seal, how could this have happened? a used phone getting mixed up with a brand new one at Nokia's factory?
Since getting the replacement I also noticed the slide feels much more positive, the old one felt like it had some wear already.
Glad I got it sorted in the end, and loving the phone dispite the hiccup.
Seems odd. Maybe it just got damaged in transit or at the factory before getting packaged. Rare, but it could happen.
No the phone had deffinatly been used, the scratches were fine but all over, kinda the area it would get worn after a lot of use. Plus the worn slide confirms it.
You should have checked the life timer as well, it shows how many hours and minutes of calls have been made on it. For future reference to show it type *#war0anty# it is basically just *#92702689#
I should have posted here 1st, thanks for that. New one says 12 mins, the calls I have made.
Thanks for this code....(my n95 8gb shows 9hrs 1min use)
Funny you say that about being used i had a G800 before i sent it back for what i have now and the box had deffo been opened as the 2 stickers eithe side were ripped and it did say on the box if they were ripped etc return, this on o2 aswell.
thanks for the tip mavity, but on my se k800i nothing seems to happen.
after typing that code in it dosent automatically do anything and it only gives me the option to send. should i send? this gives the message network problem
matt
Sorry I should have made clear that the code is only for nokias.
For se phones do the following (< and> are the joystick/pad directions)
>*<<*<* this should take you to the service menus - under tests there is an option to show total time.
thanks mavity :cool:
I got a 'new sealed' K800 phone from T Mobile shop and it had photos on there from inside the shop in a folder !!!
Ive just done this on my n82, it says 000007:00.
Ive had it since January, what does that number mean then?
