argh! What would you do? get the new astra (06) CDTi for £6000 or wait a bit and get the petrol cars listed above.![]()
Don't get the Astra!
Nope should buy her a 10 year old BMW instead.![]()
Why not driven?
You didn't want it getting dirty? or you didn't want it abused?
both
all new cars I have had before have been collect from dealer or bought on truck , I specified when I ordered it was not to be driven here
I have had loads of brand new cars before and never had one driven to me
I got my CTR driven to me (375 miles)
[TW]Fox;11296442 said:Doesnt that entirely defeat the object of buying a brand new car if it arrives to you with 375 miles on the clock? Once its been used its been used, you might as well have just saved a few grand and bought one with 5k on it!
Not really no. The car is leased, not bought, so any delivery mileage is excluded from my annual contract. Plus, having ~400 miles meant it didn't take long to run in at all (150 further miles).
[TW]Fox;11296554 said:If his car is leased I guess he isnt that bothered.
I couldn't care less if its done 400 miles by a driver or on the back of a flatbed - its the same car either way, the ONLY difference is that the odo read 375 when I got it as opposed to ~5. And it saved me running it in.
But they probably didn't run it in anyway, so you didn't save yourself anything I doubt.
true. But hes still paying for that lease?
[TW]Fox;11296635 said:No, ones a used car ones a new car. You are paying to lease a new car but its a used car that you received![]()
I think he means there's a good possibilty it has had excessive VTEC use and excessive braking by the delivery drivers, so wasn't properly run in anyway.Do you know what running in means in this context? I'm guessing not - for the FN2 CTR it basically states "avoid full throttle starts, avoid excessive VTEC use, avoid excessive braking" for the first 550ish miles. Therefore when I got it, it WAS nearly run in.
So at what EXACT mileage does a new car become used? 1 mile? 20 miles? Dealers have the ability to reset mileage upto ~40 miles on almost all new cars, once, as part of the preparation process. So, in effect, every single "new" car in the land has covered some miles (whether its 1,2,20 or 39). By your logic there is no such thing as a new car.
