It's probably higher voltage, nothing a BIOS mod can't fix![]()
Your warranty would be void once you overclocked it anyway.I assume you're right, but 98GTX is an official voltage modded version with warranty and better cooler
By saving you a lot of efforts and risks, it probably worths the extra 50 to 70 quids. But less fun I'm sure![]()
You should look a little closer its been hard modded. And I got 850 from my G92-GTS at stock. All those drivers did was fix the low scores on a couple of benches, 05/06 remained the same. They're not all that remarkable, 2500+ memory helps. 03 is ok and 01 still looks low.[3DMark03 score has jumped up from 39k to 54k.
I also notice that 9800GTX is a super clockable card. It has been clocked to 900/1269(2540)/2250MHz (CORE/RAM/SHADER)
Scary~
vs
vs
Lawl at 3D Mark 03 as well, should've put that in the title dude. Probably equates to 100 06 points or something, so typical increase from decent drivers. Sure as hell not impressed with this "next-gen."![]()
They do honour the warranty even it says no in the document as soon as the card is not badly burnt. Because most of the users are overclocking these days. The card makers will lose the market if they strickly say no and probably they would have to come to the courts in UK quite oftenly
How can you make your G92 GTS work at 850? With voltage mods?
But my source is not from the link you provided and it doesn't say anything about hard mods originally. I'll keep my fingers cross![]()
same mod as 88gts/gt.
500ohm vr,
900/1269mhz, shader=2250(actually 2268), 3Dmark01/03/05/06 test:
Most impressive GTS overclock I've seen is this one, noticed it a couple of months ago
http://www.techpowerup.com/gpuz/84me5/
You might want to read the RMA T&Cs on some manufacturer sites mate.Many manufacturers actually keep silent on overclocking things if they are not encouragingThey do honour the warranty even it says no in the document as soon as the card is not badly burnt. Because most of the users are overclocking these days. The card makers will lose the market if they strickly say no and probably they would have to come to the courts in UK quite oftenly
fornowagain, i think you're right. but the source i quoted from is mydriver.com
they did not mention about the mods.
anyway, i think you are extremely lucky to get the clock way up to 850. i've tested at least 30pcs of 88GTS from variety of brands, none of them can walk pass 760MHz mark. And I've seen the report about the limits of current G92 chips, either GT or GTS. It's 756MHz.
Scary~~
Out of topic, do you guys know where I can get that E3110 Xeon in UK? It's extremely popular in US because it's a server version of E8400.
You might want to read the RMA T&Cs on some manufacturer sites mate.![]()
Quite a few of us managed in excess of 800+ when the cards first came out.
See for yourself > http://forums.overclockers.co.uk/showthread.php?t=17814707
The same for the GT, a little VID tweak in the bios got a few to 775+, mine made it to just under 800 with no volt mods.
Matey, don't quote me anything just in docs! I'm telling the facts in this business, in another word, pramatically. I'm a reseller and I know every bits of it. And pls do read my post before trying to be cleaver! I can't talk about this any further because it would harm the retailing business.
and How would it hurt the retail business talking about overclockingand
dont you work for a review site?
OCOCOC, have you gone on a mad one agian![]()
Anyway, if we are not talking about overclocking, the GTX is still 25/75/400MHz ish faster than GTS with much better RAM. That makes the card cooler and quieter. It still worths the extra money for those who haven't own the G92![]()
