two raptors?
12 Jun 2007
Ireland
I'm looking to get another raptor x 10rpm and then used them in raid 0.
But here is the question if i want to raid them will i have to reformat mine hardrive? i never had raid so i'm clueless
Yes. You will need to create a raid array so your motherboard creates a 'single' hard disk out of the two. The raid controller then splits the data into clusters and spreads the info over both drives which in turn cuts down the seek/read/write time as it is using 2 drives at once.
Depends....what motherboard do you have ?
There is a way around a reformat if you wish to keep your data intact ;)
ive also thought of doing raid with my raptor, its question iv ebeen thinking to ask to, also does it make it any more noiser? having 2 raptors
I would just back your data up and do a complete reinstall, will give you the chance to slipstream and slim down the OS too.
