Ah go me hah, I thought it was just a download linkthe description is in the link that the op provided![]()
Thanks!
You also need both of the episodes.
But you might want to look at some of the older versions of the mod, they all have very good textures, and the new intro moive is always worth a watch.
I own the eppisodes, they run fine on my PC, but this mod seems to be quite demanding considering what it does![]()
anyone care to make a torrent for this?
it should spread like wildfire on these forums![]()
i would but with a 75k upload it'd take longer than downloading it from filefront lol
im only just installing it now. the installer says i need 20gb of space for it lol
Typical after I just downloaded 4.7GB of version v6!
Curse you a thousand times!![]()
it drops to the high 20's in the big areas but there's no real problem with it
oh you also need episode 1 and 2 installed and working, to use it as it uses the orange box's modified engine.
It needs at least 3GB RAM and it's not recommended to use 32-bit OS.Should I recommend this to my mate? He's playing HL2 for the first time at the moment, on;
BFG 8800GTS 512MB OC / 2GB RAM / Q6600 / Windows XP 32bit
... or should I just leave him to play the game 'as it should be' and without the potential crashes?
Also, does this load like a mod (e.g. easy to turn on/off) or does it permanently alter the game?
And do savegames from vanilla HL2 work with cinematic HL2?
