The dip stick was a bit flimsy too....
Does the E38 not tell you the oil level? Dip stick in the s's is for use only if the computer is reporting a weird reading or the sensor is broken or something
Does the E38 not tell you the oil level? Dip stick in the s's is for use only if the computer is reporting a weird reading or the sensor is broken or something![]()
Oooh, while I remember, Washer filler bottles?? WHY are they usually so damn narrow and in awkward places, everytime you get a 5ltr bottle of screenwash, half a litre ends up on your feet![]()
I dont know how to turn my Mk2 Golfs rear window wiper off after i've turned it on![]()
Ford headlight stalk.
On most cars, you push the stalk forwards to lock on main beam, bring it bank central to turn off main beam. Pulling the stalk toward you will flash the main beam and then return normally by a spring.
On my Focus, both actions are done by pulling it toward you. So you pull it halfway for flash and it springs back, or all the way to lock full beam on. Unfortunately, it requires only very gentle pressure. The amount of times Ive gone to flash an oncoming driver only to lock the full beam on, blinding them...its about the only thing I don't like about my car![]()
Yes! Same with my Focus and i've done that many times tooAlso have you mistakenly flashed people whilst indicating?
Aww ya poor thing. Don't you check the difficult fit guide?
