GT5: Prologue Europe Extra Features
Looking at that F40 video and the throttle position indicators in the bottom right corner, he seems to be able to keep the right foot pretty much planted on the exit of the corners without any problems at all. I'd of expected a little more oversteer on something with as much grunt as an F40! Hope it's not totally arcady. :(
is it worth importing a dualshock controller for this game?
if anyone wants to add me on psn in time for this :
psn id: beachboyken
cheers
what exactly is understeer and oversteer and how would i master it on gt5p ,is it about setting up the car?
Understeer is when the car slides over the front tyres and goes straight on when you turn, oversteer is when the rear end of the car turns faster than the front.
To correct understeer increase front downforce and decrease rear downforce, set brake balance more to the rear, brake before the bend not while entering a corner.
To correct oversteer do the opposite regarding downforce and when accelerating out of a corner do not slam on the throttle but do it a little slower and if the rear end does step out steer the other way to correct the slide.
psn id: beachboyken
cheers
Yes yes yes, imo the game feels flat without the DS3, but since getting mine it's given the game a new lease of life :D
Also the DS3 is far better than the six axis in every way, I can't recommend it enough tbh..
it was done in standard mode not pro
I really am excited about this and i pre-ordered online so should receive it on friday but a day earlier would be nice :D going by people's opinion's of the jap version a wheel is must to get the best out of the game but i will have to do without because i cant afford to get one and in the future if i do buy one i wont spend a fortune on one , what is a good wheel at a cheaper price £80 max ?
