HL2 Texture Packs?
Status
Not open for further replies.
26 Feb 2007
Around
Are there any texture packs that run on 32bit and dont make alex look like a pig?
thanks.
I've highlighted the important bits so people dont recommend Cinematic mod.
And cue Cinematic mod defence force.
I've been checking in on the progress of the Cinematic mod for a while now and I've never heard of any competition. Shame.
cinematic mod v4.0
http://halflife2.filefront.com/file/FakeFactorys_Cinematic_Mod;77368
Still a quality release, works with HL2, HL2:Ep1
Used this one when it first came out (on a 32-bit OS, 1GB, nvidia 7900 system), and it worked fine/looked pretty good.
it's got a higher poly model of alyx which is a little different here and there but her face is recognisable and she's not sporting a wonderbra.
Some screens I took ages ago (I used a version of alyx with tied back hair, but you can use a high poly version with default styled hair too)
cinematic mod v4.0
Utter Fail. Totalitarian Failation.
The high poly version doesnt look too bad, not as bad as the as the new busty one in v6.
you can still use the old model anyways:
thanks.
I started a thread explicitly to discuss something other than Cinematic mod. IE, i dont want to talk about Cinematic Mod.
There is a cinematic mod thread. if i wanted to know about it, i would have used that thread.
I cant really explain it any better than that.
But if the previous version works with 32bit and doesn't give her big knockers, then what's the problem? The thread is talking just about the latest version. Oh well :confused:
cinematic mod lets you use a number of differnt models for alyx:rolleyes:
i cant really see what difference it makes anyway, you dont spend an awful lot of time with her. if i want to look at sexy ladyiizz i just at the GF, not a bunch of polygons on hl2 lol
Ah, blindly ignoring the fact that you can get rid of your one problem with it (according to your OP, that Alyx "looks like a pig") surely makes you the clever one and everyone else responding stupid... :rolleyes:
(also: it runs fine on 32bit, just don't run it in highest mode if you want to be safe)
My "problem" is i wanted an alternative to Cinematic Mod. I made that ABUNDANTLY clear. So gtfo of the thread, please.
Russ0r already answered my question a long time ago, so you kids can run back the the Cinematic thread now. thanks for your time.
Status
