ATI hotfix now available
Caporegime
18 Oct 2002
Ireland
http://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=33033
737-33033: ATI Radeon HD2xxx/HD3xxx: Intermittent stuttering issues seen when running various 3D applications
The information in this article applies to the following configuration(s):
Radeon™ HD3870 series
Radeon™ HD3850 series
Radeon™ HD2900 series
Radeon™ HD2600 series
Radeon™ HD2400 series
Windows Vista 32-bit Edition
Windows Vista 64-bit Edition
Windows XP Professional
Windows XP Home Edition
Windows XP Media Center Edition
Windows XP Professional x64 Edition
Symptoms:
Solution:
Download and install the following Hotfix by clicking on the appropriate link below:
At last ! fingers crossed this sorts it. Been well impressed with the cards 3D perfomance in Dirt ! Orange box, Stalker etc but it sometimes flickers like crazy in browsers, Cinema 4D dual screen & sam & max.
Its just a hotfix to sort the powerplay problem.Your have to wait for the true 8.4 to see any real boost.(if any from 8.4) never expected a boost but will be more than happy if it sorts the PP issue until 8.4 shame it took so long .
Its the same in COD4 for me as Cat 8.3's bad screen flicker following flash nade.....I think I will be rolling back to 8.2 and wait for 8.4 :(
Is there a problem with powerplay with the single gpu 3870s cos I haven't noticed it..I know it's with the 3870x2?
Maybe I should put the hotfix on in case...
is it just me or does my card run hotter than it did before the hotfix was applied ? , it hit 76c while playing bioshock but before it only hit 68c . i have noticed though it ran smoother and looked alittle better
It makes sense with it running hotter with it not now clocking down with the issue sorted - temps not getting a break which is what it should be like now.
