8800 GTS 320Mb overclock
I've got it to 601/819/1420 atm on stock cooling. idling at about 67C and about 84C on load.
My card idles at 65C and under load goes to 85C
I have watercooling and almost zero case airflow, but as the card has a variable fan it speeds up under load and I have never had stability issues.
Mine idle at 51 and 54C, and reach about 70 and 73C on load, at clocks in sig. Have you not got much airflow??
It's a TT Tsunami case with x2 120 mm fans inside, however, the area around the intake for the gpu is a bit tight.
