- 15 Jun 2007
- Manchester
Because they want to try see what card can get the extra FPS out it, most play at 1600's or 1920's today.
Doubt it, I reckon most still play at 1280x1024.
Then there is no need for them to buy a high end 8800.
You sort of missed my pointand that is playable frame rate, res then eye candy. So if say 1440x1050 = playable frame rate you can then give a fair represention of the differential between the cards in the group test.
I have a 24" dell 1920x1200 but to play a game at that res then it has to run at a playable frame rate (33fps) or it's unrealistic.
I dont have a problem with pushing a card to unrealistic settings as a part of the test but to draw any conlusions (or all in this case) on such a flaky test procedure is just plain wrong, its quite clear that the cards are not ment to play this game at such high settings and working the differance out of how poorly they performe on a % basis is... well worst than wrong, its misleading.
LOL, the old tech Ultra still the fastest Single card ? (hard to tell there)
A pointless upgrade for GTX and ultra users then.
Amen to that one brother!I dont understand why they test crysis at high res when its so clear that the card hasn't the grunt to run the game at high settings. whats wrong with testing with playable( realistic ) settings instead of quoting unplayable frame rates and giving a % of the speed differance last time i checked 50% of **** all is errm...still **** all!.
Crysis
1680x1050- 0X AA/AF @18 fps
1680x1050- 4X AA/16X AF @12 fps
1920x1200- 0X AA/AF @14 fps
I disagree, what if you want to play Crysis on very high with AA/AF? Even an 8800 won't do it smoothly at 1280x1024.
