WOW! how did you get that score with so little overclock!
what are the rest of your spec? using an nVidia motherboard?
and wtf? Antx777, how come you got even higher with less overclock?
again, nVidia motherboard by any chance?
32ish
~Ant
i was suspecting that, since Antx777 only got 12FPS minimum.it says disabled but he's running SLI.
GPU-Z aint all that yet
what cpu? seems crazy that just going for 32bit you can get a 50% increase on my score with a lower clocked GTX.. unless you have 2? I guessed you didn't because gpuz says sli is disabled?
Why did you miss out the cpu speed on two of the results?
On ChronicTank and LeeBone?
Granted - you can click on the score and look at the screenshot but it's still not up though like the others.
Just my two cents.
it's up to the user to input their cpu score when they fill out the form.
Holy shizzle, simonmaltby I believe is the first person who has a PC capable of truly running crysis on very high. Nice results.
ok . I check this new list a lot to see how the cards do - interesting list.
Yeah good results but would be play with the cpu so high or does he put the cpu up so high for just benchmarking and then downclock it after?
That cpu is up at very high clocks.![]()
