fair enough, but for me it's Castrol or nothing.
Yea, really matters in a 13 year old 1.6 litre petrol engine
pretty much impossible I'd of thought?
I heard on here thats what Smart do (Smart Cars) because there is no drain plug sump (wtf?) But for a normal car, how would the pipe get feed all through the block to the sump? Too much stuff in the way, non?
Its called a Pella Pump and it slots down the dipstick feed.
Yep. The longest part is waiting for the old stuff to drain out. The last oil change I did was on the 200SX, jacked it up so you can slide a drip tray underneath (90 seconds maybe?), undo the sump plug, (10 seconds), stand up and reach down into the bay and undo the old filter by hand (45 seconds)
Wait for it to drain (some cars drain fast, some don't)
Wipe off any oil that's drooled over the block (45 seconds) replace filter (20 seconds) do up sump plug, slide out drip tray, lower car (60 seconds) fill oil (30 seconds)
DONE
Agreed in principle, when we did my mates S14 it was relatively painless (despite having the dodgiest dipstick known to man)
No word of a lie
Crap and bendy isn't it?![]()
yep cost £23 last time i did it bet its cheap and nasty oil though
Unless you have a B series Honda, then it's 45 minutes
Back me up here guys, I know I have girly wrists but it really is in a stupid position![]()
[TW]Fox;11442955 said:Yea, really matters in a 13 year old 1.6 litre petrol engine![]()
[TW]Fox;11446870 said:Thats slightly different given that the specification of the dual VANOS M54 engine requires a particular type of oil. Using the oil that was developed in conjunction with the vehicle manufacturer for that engine is hardly a daft idea. Besides - it gets what BMW put in it when it's serviced. It's no different in that regard to not putting anything but 5w30 in, say, a 96 Mondeo.
But your car doesn't ask for Castrol, it's a regular, reliable, tough, 1.6 litre petrol engine with no fancy garnish or sauce, so it doesn't need superamazing oil. Sure, don't put Tesco Value Motor Oil in it, but pouring scorn on the stuff Ford sells for 15 quid is a tad OTT, really.
Your car doesnt ask for castrol either.
[TW]Fox;11446969 said:Although there are other oils I can use from the BMWLL01 list, it does specifically say Castrol in the owners handbook and on the oil filler cap![]()
[TW]Fox;11446989 said:You know exactly what my point is even though you'd never admit that on here so lets agree to disagree.
