all x2's and phenoms but you need a 7x0 chipsetOn a side note, can anyone (AMD user obviously) use the Overdrive? or only Phenom owners, I heard it could be used on the x2's but can't find anywhere to download it. Tried AMD site and nothing.
yes you just adjust the multipilers for each coreSo wait, you can adjust the speed of a single core on a Phenom? If so, could you clock all the other cores really low and see how high each individual core clocks?
yep thats fine..I'm using the ga-ma770-ds3 mobo so thats a 770 chipset, right?
Anyone have a link to download?
EDIT: just checked manual, It has a AMD 770 North Bridge and an AMD SB600 South Bridge. Not sure which is relevant.
make sure everything is on auto in bios for the cpu...Thanks for that, downloaded it but half the functions don't work, i.e. auto clock, and I can't seem to be able to use it to increase my clock, max settings shown are stock and nothing I do increases fsb/htt
HT ref clock and pcie speed are greyed out.
