Hey guys
, I pushed mine to 440 FSB 3.5ghz (3520mhz), 1.304v, I have turned Landline calibration? to enabled which keeps the Volt you set but its still lower than I set, I set 1.32... etc. Running PRIME95 now, I ran PRIME95 for 5 hours on my 3.4ghz 1.240v setup with landline set to auto and that was fine.
I didnt want to touch 1.3v though out of fear it will damage my CPU, also about those northbridge temperatures, after running PRIME95 for 5 hours the temps stayed at 44degrees or below and in the green also when playing STALKER it didnt stay in the red anymore, I cant understand why?
Cores late 60's in CoreTemp whilst using PRIME95.
Update:
3520mhz whilst using PRIME95 makes northbridge go red after a while and then out back to green mostly I have to admit staying green though, hopping between 44 and 45-6 degrees, 3400 did not do so, I guess though its the increased voltage?
Update 2:
Ran prime for nearly 2 hours so definitly stable, Northbridge is constantly at 45 degrees red, and CPU Core temps late 60's early 70's, is it worth it? I know My system will almost never be pushed like this though so I guess it is.When stopped temps come down to mid 50's as normal and early 40's for north bridge. SuperPI at 1MB was 1/2 a second faster with 3.5ghz than 3.4ghz at 13.203seconds
ATLANT3AN
What truly is hands on heart the safest cpu voltage for these Q9series? which wont result in any loss of life span? I dont know If I should go back to 3400 with 1.2v. I cant change computer for 3 years and when I get a new one this will become my second machine, so really 5 years is the lifespan of my machine, if It will easily reach that then I dont mind.
