Masters course - does time after BSc matter?
[TW]Fox;11459373 said:
I dont think it will matter however one big consideration for you, and the reason why I've pretty much decided to do an MSc right after my degree and not wait, is that once you get used to the real world and earning real money you'll find it very hard to go back and get into student mode again.
Ha, I'm starting a full time M.Sc. in the autumn after 8 years of high paid work...
What advantages does a masters give you when going into jobs? Say I did a masters in maths, where would that put me about the standard degree?
£5k for a masters? Are you being serious?!
can be less than that too - some are about 3k or so and others have plenty of grants available where you basically get the course & some living expenses taken care of - tis a bit different to the US as in the UK the govt still funds most higher education courses - UK students only have to pay a small portion of the fees
though we do have a few exceptions - finance masters, for example, can cost 20 grand or so
some places will give you a bigger starting salary (at my firm it is about 5k extra for masters grads in the first year - obviously this has a knock on effect on further pay rises)
there are also some jobs out there that pretty much require masters degrees
I'm sure when i checked a masters in Psychology (or related) was about 4k (give or take). Mind you that was at like MMU, Salford, Bolton. Not the best Uni's around.
I graduated back in 2002 from University of Sheffield with a BEng in Electronic Engineering with Communications.
I did have a few options open to me, to continue onto a PhD at Sheffield (skip Masters), I was also entertaining the possibility of a Masters in Electronics and Photonics at Warwick Uni, but I gave both avenues a miss and decided to get stuck in and get some industrial experience under my belt.
5 years on and I have now started a 3 year MBA course at Warwick Uni and so far I'm finding that I can still get back into the study groove so to speak :)
So you could always leave uni for a little while and then come back later if you feel confident enough!
[TW]Fox;11460591 said:
Really, have you finished your undergrad already? Time flies :eek:
Should have said masters choices, finishing undergrad in a couple of months, time does indeed fly!
All ye doing masters prepare to be sickened.....i'm just about to finish my masters in computer science and cybernetics and in tuition fees it has cost me £550 ^_^
There is nothing wrong with a 2.2 - it's a solid degree. Although I was 1.4% away from a 2.1 - maybe I should have got it remarked? I'm happy either way.
Back OT, I was looking at doing a masters directly after my degree or going to Liverpool and doing a degree in Classics. The cost just seemed too much so I didn't go much pursue it much further.
There is a lot of things wrong with a 2.2, it severely cuts down your chances to get opportunities in the city, especially banking and consultancy.
Yeah but it sounds like you've got it from Reading so its probably not even worth £550. :P (J/K)
Whilst it is a good degree, you might struggle to be accepted to some higher education courses or graduate schemes.
Graduate schemes seem more bothered about your UCAS points than your degree classification. Got a 2:2? Come on board, provided that years ago when you wore a school blazer you spent your time doing revision instead of Counter-Strike. Got a 2:1 or even a 1st? Well.... go away ;)
A 2:2 is not a decent degree classification IMO.
I strongly disagree.
But oh well.
I graduated from Warwick with a 2:2 and went back for a MSc at the Warwick Manufacturing Group with required only a 2:2 :)
I know :( Its the reason why I decided to do a Masters...
Why are you being so defeatest? It isn't a bad degree. If you think it's that bad then you're stupid for not resitting imo.
It's a good job I'm not in to banking then eh.
Still unsure if I shoulda got my results remarked for the 1.5%?
