HI there
Here is just a handful of the amazing deals on This Week Only for you guys to sink your teeth into, I think you will agree that OcUK is the cheapest by quite some margin:-
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit (BL2KIT12864AA663)
The Ballistix line is specifically built for performance enthusiasts who want to push the performance envelope without worrying about data loss or corruption, mysterious intermittent errors and display problems, or worse — the dreaded BSOD! The Ballistix line of high-performance memory modules features advanced speed grades, low latencies, and integrated aluminum heat spreaders.
- Module Size: 2GB kit (1GBx2)
- Package: 240-pin DIMM
- Feature: DDR2 PC2-5300
- DIMM Type: UNBUFFERED
- Speed: DDR2-667
- Voltage: 2.2V
- Memory Timings: CL=3
- Warranty: Lifetime
- For warranty support and RMA replacement call Crucial Direct on 0800 013 0330 or 01355 586 100 who will replace your faulty memory within 48 hours.
Price: £24.99+VAT (£29.36 inc VAT)
BUY NOW!
OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK)
As part of OCZ’s Gold series, the PC2-6400 2GB modules deliver the performance and speed gamers require for today’s graphic-intensive DirectX 10 PC games. At 800MHz, the 2GB Gold Edition runs at 5-5-5 latency timings and offers unprecedented stability on the latest AMD and Intel platforms. As a Vista up-grader, the PC2-6400 4GB dual channel kit will provide excellent memory bandwidth and deliver the best possible gaming and productivity on Vista systems.
All Gold Edition modules are 100% hand-tested for quality assurance and compatibility and feature high quality, gold-mirrored XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ Gold series module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
* XTC (Xtreme Thermal Convection) heatspreaders optimize the thermal management of memory modules by promoting greater airflow by means of micro-convection throughout what is usually the dead air space inside conventional heatspreader designs. In this manner, build-up of heat is avoided and thermal dissipation of the memory components is offloaded more efficiently through the honeycomb design. At the same time, mechanical stability is maintained.
**OCZ EVP (Extended Voltage Protection) is a feature that allows performance enthusiasts to use a VDIMM of 2.1V ± 5% without invalidating their OCZ Lifetime Warranty.
- 800MHz DDR2
- CL 5-5-5-18
- Unbuffered
- Gold XTC* Heatspreader
- OCZ Lifetime Warranty
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
Price: £41.99+VAT (£49.34 inc VAT)
BUY NOW!
OCZ 2GB (2x1GB) PC2-8500C5 1066MHz Reaper HPC Edition Dual Channel DDR2 (OCZ2RPR10662GK)
The Reaper HPC is an innovative cooling solution developed by OCZ to effectively minimize heat produced by high-speed memory. As heat rises into the thermo-conductive copper heat pipe conduit, it is dissipated through the strategically-placed compact aluminum fin array. By guiding performance-robbing heat away from key memory components, the unique Reaper HPC design helps facilitate improved overclocking performance, while improving longevity and stability of the modules. The first modules to be incorporated with the new Reaper heatsink are rated at 1066MHz and run at CL 5-5-5. Featuring an EPP (Enhanced Performance Profiles) programmed SPD, PC2-8500 Reaper HPC modules will immediately boot at the rated specs on the latest generation of NVIDIA® SLI™ chipsets. Although the OCZ Reaper HPC series was coined for enthusiasts, EPP eliminates the need for manual configuration and makes memory optimizations a household item for the complete range of consumers looking to maximize system performance through overclocking. As part of OCZ’s line-up of premium memory, PC2-8500 modules are backed by a Lifetime Warranty and industry-leading technical support.
* The Reaper HPC series uses heat pipe technology to rapidly remove heat from the main body of the memory modules and conduct the thermal load to the extended radiator fin array. The addition of the extended fin array nearly doubles the total surface area available for heat dissipation while the heat pipes warrant near isothermicity throughout the entire design. The result is a doubling in effective heat dissipation at equal delta t or, in real systems, a significantly lower operating temperature of the memory modules.
**OCZ EVP (Extended Voltage Protection) is a feature that allows performance enthusiasts to use a VDIMM of 2.35V without invalidating their OCZ Lifetime Warranty.
- 1066MHz DDR2
- EPP 5-5-5-15 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- 2.3 Volts
- 240 Pin DIMM
- Reaper HPC Heatsink*
- EPP-Ready
- 2.35V EVP**
Price: £37.99+VAT (£44.64 inc VAT)
BUY NOW!
LG GGC-H20L Blu-Ray Reader & HD-DVD ROM Serial ATA Drive - Retail
Introducing the GGC-H20L, supporting the next generation of optical disc formats. The Blu-ray disc format offers more than five times the storage capacity of traditional DVDs and can hold up to 25GB on a single-layer disc and 50GB on a dual-layer disc. Not only can you playback the BD format, you can also read and play HD-DVDs. The drive is also capable of burning DVDs and features the Lightscribe labelling function.
- BD-R Read: 6x
- BD-RE Read: 2x
- HD DVD Read: 3x
- DVD+R: 16x, DVD-R: 16x
- DVD+R DL: 4x, DVD-R DL: 4x
- DVD+RW: 8x, DVD-RW: 6x
- DVD-RAM: 5x
- DVD-ROM Read: 16x
- CD-R Write: 40x
- CD-RW Write 24x
- CD Read: 40x
- Buffer Size: 4MB
- SATA Interface
- Lightscribe Labelling Function
- Includes: PowerDVD BD & HD-DVD, SATA Cable, Power Adapter, Screws & Instructions
Price: £72.99+VAT (£85.76 inc VAT)
BUY NOW!
PNY GeForce 9600 GT 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
The NVIDIA GeForce 9600 GT GPU offers a powerfully immersive entertainment experience designed for extreme high-definition gaming and video playback. Play the hottest DirectX 10 games with awsome speed and watch the latest HD DVD and Blu-ray movies with brilliant clarity, powered by the revolutionary PureVideo HD Engine. Couple a Geforce 9600 GT based graphics card with an NVIDIA nForce motherboard for an optimal graphics platform, allowing you to ramp up your gaming horsepower with NVIDIA SLI Technology support for the most demanding games. With GeForce 9600 GT GPU, amazing graphics performance is now within your reach.
- GeForce 9600 GT core running at 650MHz
- Shader Clock Speed of 1625MHz
- 512MB GDDR3 Memory running at 1800MHz
- 256-Bit Memory Interface
- 64 Stream Processors
- Shader Model 4.0
- Memory Bandwidth: 57.6GB/s
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready – Upto 2x the performance of a single GPU (Available on with future driver release)
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
Price: £81.99+VAT (£96.34 inc VAT)
BUY NOW!
Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ)
The Samsung Spinpoint F1 is the first three-disk hard drive delivering a whopping 1TB of capacity along with sophisticated recording technology. With its compact, lightweight package and advanced design, the F1 drive offers many advantages for high-density applications compared to using two 500GB drives or a four or five-disk solution. Compared to a five-disk 1TB solution, the F1 Series consumes 13-16% less power and provides up to 20% faster performance. This 3Gbps SATA drive has a maximum of 334GB of formatted capacity per disk while also featuring Samsung’s industry-leading NoiseGuard and SilentSeek‚ technologies to eliminate acoustic noise. The Spinpoint F1 utilizes Samsung-developed perpendicular recording technology, which helps the drive set new records in both areal density and platter capacity.
- Capacity: 1TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 7200RPM
- Seek Time: 8.9ms
- Warranty: 3 Years
Price: £97.99+VAT (£115.14 inc VAT)
BUY NOW!
PNY GeForce 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Your search for the perfect graphics card is over. The ideal combination of power, performance, and price, the NVIDIA® GeForce® 8800 GT graphics card offers 112 stream processors, a 512MB 256-bit frame buffer, standard-setting GeForce 8 Series features and, a strikingly immersive DirectX 10 gaming experience. Ultra-realistic smoke, rain, explosions, lighting, terrain deformation and motion blur enable jealousy-inducing, lightning-fast gameplay in the hottest games, including Crysis, Hellgate: London, Call of Duty 4, and Gears of War. With full support for PCI Express 2.0 and featuring second generation NVIDIA PureVideo™ HD engine, the SLI™-Ready NVIDIA GeForce 8800 GT graphics card was worth the wait.
- GeForce 8800 GT core running at 600MHz
- Shader Clock Speed of 1500MHz
- 112 Stream Processors
- Shader Model 4.0
- HDCP Enabled!!
- Warranty details: If you card fails within the first 30 days of ownership then RMA with OcUK. If it fails after 30 days then contact PNY direct on 0870 423 1103 for an RMA.
BUY NOW!
EVGA GeForce 8800 GT 512MB KO GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (512-P3-N805-A1)
Your search for the perfect graphics card is over. The ideal combination of power, performance, and price, the EVGA NVIDIA® GeForce® 8800 GT graphics card offers 112 stream processors, a 512MB 256-bit frame buffer, standard-setting GeForce 8 Series features and, a strikingly immersive DirectX 10 gaming experience. Ultra-realistic smoke, rain, explosions, lighting, terrain deformation and motion blur enable jealousy-inducing, lightning-fast gameplay in the hottest games, including Crysis, Hellgate: London, Call of Duty 4, and Gears of War. With full support for PCI Express 2.0 and featuring second generation NVIDIA PureVideo™ HD engine, the SLI™-Ready EVGA NVIDIA GeForce 8800 GT graphics card was worth the wait.
- GeForce 8800 GT core running at 675MHz
- Shader Clock Speed of 1675MHz
- 512MB GDDR3 Memory running at 1950MHz
- Shader Model 4.0
- Memory Bandwidth: 60.6GB/s
- HDCP Enabled!!
- 10 Year Warranty Direct with EVGA on 0049 8918904911 (TOLL FREE)
- 90 Day Step-up/upgrade programme from day of purchase (Upgrade your card and only pay the difference direct with EVGA)
- 24/7 Email Support at [email protected]
- All RMA's & Upgrades are dealt with between EVGA Direct and the Consumer on 0049 8918904911
Price: £116.99+VAT (£137.46 inc VAT)
BUY NOW!
AMD Phenom Quad Core 9850 2.50GHz Black Edition (Socket AM2) - Retail
The AMD Phenom processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance.
AMD releases the new AMD Phenom™ 9850 Black Edition quad-core processor with Clock Multiplier Control for tunable performance. The newest Black Edition processor can improve platform performance by unlocking the potential of AMD OverDrive™– the industry’s most powerful Windows-based performance tuning utility.
- True Quad-core Desktop Processor
- Unlocked Multiplier for the ultimate overclocking flexibility
- 2.50GHz clock speed
- 2MB L2 cache
- 2MB L3 cache
- DDR2-1066 support
- 65nm process technology
- Integrated Memory Controller
- Fast Hypertransport 3.0 technology
- Cool & Quiet v2.0
- Heatsink & Fan included
Price: £131.99+VAT (£155.09 inc VAT)
BUY NOW!
- Speed: DDR2-667
- Voltage: 2.2V
BUY NOW!
- 800MHz DDR2
- CL 5-5-5-18
- Unbuffered
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
BUY NOW!
- 1066MHz DDR2
- Unbuffered
- 2.3 Volts
- 240 Pin DIMM
- EPP-Ready
- 2.35V EVP**
BUY NOW!
- BD-R Read: 6x
- BD-RE Read: 2x
- HD DVD Read: 3x
- DVD-RAM: 5x
- DVD-ROM Read: 16x
- CD-R Write: 40x
- CD-RW Write 24x
- CD Read: 40x
- Buffer Size: 4MB
- SATA Interface
BUY NOW!
- Shader Model 4.0
- HDCP Enabled!!
BUY NOW!
- Capacity: 1TB
- Cache: 32MB
- Seek Time: 8.9ms
- Warranty: 3 Years
BUY NOW!
- Shader Model 4.0
- HDCP Enabled!!
BUY NOW!
- Shader Model 4.0
- HDCP Enabled!!
BUY NOW!
- 2MB L2 cache
- 2MB L3 cache
- DDR2-1066 support
- Cool & Quiet v2.0
BUY NOW!
dont think you can find lower than that.
