Amazing TWO Deals, we really are the UK's cheapest and in stock!
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
Here is just a handful of the amazing deals on This Week Only for you guys to sink your teeth into, I think you will agree that OcUK is the cheapest by quite some margin:-
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit (BL2KIT12864AA663)
The Ballistix line is specifically built for performance enthusiasts who want to push the performance envelope without worrying about data loss or corruption, mysterious intermittent errors and display problems, or worse — the dreaded BSOD! The Ballistix line of high-performance memory modules features advanced speed grades, low latencies, and integrated aluminum heat spreaders.
- Module Size: 2GB kit (1GBx2)
- Package: 240-pin DIMM
- Feature: DDR2 PC2-5300
- DIMM Type: UNBUFFERED
- Speed: DDR2-667
- Voltage: 2.2V
- Memory Timings: CL=3
- Warranty: Lifetime
- For warranty support and RMA replacement call Crucial Direct on 0800 013 0330 or 01355 586 100 who will replace your faulty memory within 48 hours.
Price: £24.99+VAT (£29.36 inc VAT)
BUY NOW!
OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK)
As part of OCZ’s Gold series, the PC2-6400 2GB modules deliver the performance and speed gamers require for today’s graphic-intensive DirectX 10 PC games. At 800MHz, the 2GB Gold Edition runs at 5-5-5 latency timings and offers unprecedented stability on the latest AMD and Intel platforms. As a Vista up-grader, the PC2-6400 4GB dual channel kit will provide excellent memory bandwidth and deliver the best possible gaming and productivity on Vista systems.
All Gold Edition modules are 100% hand-tested for quality assurance and compatibility and feature high quality, gold-mirrored XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ Gold series module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
* XTC (Xtreme Thermal Convection) heatspreaders optimize the thermal management of memory modules by promoting greater airflow by means of micro-convection throughout what is usually the dead air space inside conventional heatspreader designs. In this manner, build-up of heat is avoided and thermal dissipation of the memory components is offloaded more efficiently through the honeycomb design. At the same time, mechanical stability is maintained.
**OCZ EVP (Extended Voltage Protection) is a feature that allows performance enthusiasts to use a VDIMM of 2.1V ± 5% without invalidating their OCZ Lifetime Warranty.
- 800MHz DDR2
- CL 5-5-5-18
- Unbuffered
- Gold XTC* Heatspreader
- OCZ Lifetime Warranty
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
Price: £41.99+VAT (£49.34 inc VAT)
BUY NOW!
OCZ 2GB (2x1GB) PC2-8500C5 1066MHz Reaper HPC Edition Dual Channel DDR2 (OCZ2RPR10662GK)
The Reaper HPC is an innovative cooling solution developed by OCZ to effectively minimize heat produced by high-speed memory. As heat rises into the thermo-conductive copper heat pipe conduit, it is dissipated through the strategically-placed compact aluminum fin array. By guiding performance-robbing heat away from key memory components, the unique Reaper HPC design helps facilitate improved overclocking performance, while improving longevity and stability of the modules. The first modules to be incorporated with the new Reaper heatsink are rated at 1066MHz and run at CL 5-5-5. Featuring an EPP (Enhanced Performance Profiles) programmed SPD, PC2-8500 Reaper HPC modules will immediately boot at the rated specs on the latest generation of NVIDIA® SLI™ chipsets. Although the OCZ Reaper HPC series was coined for enthusiasts, EPP eliminates the need for manual configuration and makes memory optimizations a household item for the complete range of consumers looking to maximize system performance through overclocking. As part of OCZ’s line-up of premium memory, PC2-8500 modules are backed by a Lifetime Warranty and industry-leading technical support.
* The Reaper HPC series uses heat pipe technology to rapidly remove heat from the main body of the memory modules and conduct the thermal load to the extended radiator fin array. The addition of the extended fin array nearly doubles the total surface area available for heat dissipation while the heat pipes warrant near isothermicity throughout the entire design. The result is a doubling in effective heat dissipation at equal delta t or, in real systems, a significantly lower operating temperature of the memory modules.
**OCZ EVP (Extended Voltage Protection) is a feature that allows performance enthusiasts to use a VDIMM of 2.35V without invalidating their OCZ Lifetime Warranty.
- 1066MHz DDR2
- EPP 5-5-5-15 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- 2.3 Volts
- 240 Pin DIMM
- Reaper HPC Heatsink*
- EPP-Ready
- 2.35V EVP**
Price: £37.99+VAT (£44.64 inc VAT)
BUY NOW!
LG GGC-H20L Blu-Ray Reader & HD-DVD ROM Serial ATA Drive - Retail
Introducing the GGC-H20L, supporting the next generation of optical disc formats. The Blu-ray disc format offers more than five times the storage capacity of traditional DVDs and can hold up to 25GB on a single-layer disc and 50GB on a dual-layer disc. Not only can you playback the BD format, you can also read and play HD-DVDs. The drive is also capable of burning DVDs and features the Lightscribe labelling function.
- BD-R Read: 6x
- BD-RE Read: 2x
- HD DVD Read: 3x
- DVD+R: 16x, DVD-R: 16x
- DVD+R DL: 4x, DVD-R DL: 4x
- DVD+RW: 8x, DVD-RW: 6x
- DVD-RAM: 5x
- DVD-ROM Read: 16x
- CD-R Write: 40x
- CD-RW Write 24x
- CD Read: 40x
- Buffer Size: 4MB
- SATA Interface
- Lightscribe Labelling Function
- Includes: PowerDVD BD & HD-DVD, SATA Cable, Power Adapter, Screws & Instructions
Price: £72.99+VAT (£85.76 inc VAT)
BUY NOW!
PNY GeForce 9600 GT 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
The NVIDIA GeForce 9600 GT GPU offers a powerfully immersive entertainment experience designed for extreme high-definition gaming and video playback. Play the hottest DirectX 10 games with awsome speed and watch the latest HD DVD and Blu-ray movies with brilliant clarity, powered by the revolutionary PureVideo HD Engine. Couple a Geforce 9600 GT based graphics card with an NVIDIA nForce motherboard for an optimal graphics platform, allowing you to ramp up your gaming horsepower with NVIDIA SLI Technology support for the most demanding games. With GeForce 9600 GT GPU, amazing graphics performance is now within your reach.
- GeForce 9600 GT core running at 650MHz
- Shader Clock Speed of 1625MHz
- 512MB GDDR3 Memory running at 1800MHz
- 256-Bit Memory Interface
- 64 Stream Processors
- Shader Model 4.0
- Memory Bandwidth: 57.6GB/s
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready – Upto 2x the performance of a single GPU (Available on with future driver release)
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
Price: £81.99+VAT (£96.34 inc VAT)
BUY NOW!
Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ)
The Samsung Spinpoint F1 is the first three-disk hard drive delivering a whopping 1TB of capacity along with sophisticated recording technology. With its compact, lightweight package and advanced design, the F1 drive offers many advantages for high-density applications compared to using two 500GB drives or a four or five-disk solution. Compared to a five-disk 1TB solution, the F1 Series consumes 13-16% less power and provides up to 20% faster performance. This 3Gbps SATA drive has a maximum of 334GB of formatted capacity per disk while also featuring Samsung’s industry-leading NoiseGuard and SilentSeek‚ technologies to eliminate acoustic noise. The Spinpoint F1 utilizes Samsung-developed perpendicular recording technology, which helps the drive set new records in both areal density and platter capacity.
- Capacity: 1TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 7200RPM
- Seek Time: 8.9ms
- Warranty: 3 Years
Price: £97.99+VAT (£115.14 inc VAT)
BUY NOW!
PNY GeForce 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Your search for the perfect graphics card is over. The ideal combination of power, performance, and price, the NVIDIA® GeForce® 8800 GT graphics card offers 112 stream processors, a 512MB 256-bit frame buffer, standard-setting GeForce 8 Series features and, a strikingly immersive DirectX 10 gaming experience. Ultra-realistic smoke, rain, explosions, lighting, terrain deformation and motion blur enable jealousy-inducing, lightning-fast gameplay in the hottest games, including Crysis, Hellgate: London, Call of Duty 4, and Gears of War. With full support for PCI Express 2.0 and featuring second generation NVIDIA PureVideo™ HD engine, the SLI™-Ready NVIDIA GeForce 8800 GT graphics card was worth the wait.
- GeForce 8800 GT core running at 600MHz
- Shader Clock Speed of 1500MHz
- 112 Stream Processors
- Shader Model 4.0
- HDCP Enabled!!
- Warranty details: If you card fails within the first 30 days of ownership then RMA with OcUK. If it fails after 30 days then contact PNY direct on 0870 423 1103 for an RMA.
BUY NOW!
EVGA GeForce 8800 GT 512MB KO GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (512-P3-N805-A1)
Your search for the perfect graphics card is over. The ideal combination of power, performance, and price, the EVGA NVIDIA® GeForce® 8800 GT graphics card offers 112 stream processors, a 512MB 256-bit frame buffer, standard-setting GeForce 8 Series features and, a strikingly immersive DirectX 10 gaming experience. Ultra-realistic smoke, rain, explosions, lighting, terrain deformation and motion blur enable jealousy-inducing, lightning-fast gameplay in the hottest games, including Crysis, Hellgate: London, Call of Duty 4, and Gears of War. With full support for PCI Express 2.0 and featuring second generation NVIDIA PureVideo™ HD engine, the SLI™-Ready EVGA NVIDIA GeForce 8800 GT graphics card was worth the wait.
- GeForce 8800 GT core running at 675MHz
- Shader Clock Speed of 1675MHz
- 512MB GDDR3 Memory running at 1950MHz
- Shader Model 4.0
- Memory Bandwidth: 60.6GB/s
- HDCP Enabled!!
- 10 Year Warranty Direct with EVGA on 0049 8918904911 (TOLL FREE)
- 90 Day Step-up/upgrade programme from day of purchase (Upgrade your card and only pay the difference direct with EVGA)
- 24/7 Email Support at [email protected]
- All RMA's & Upgrades are dealt with between EVGA Direct and the Consumer on 0049 8918904911
Price: £116.99+VAT (£137.46 inc VAT)
BUY NOW!
AMD Phenom Quad Core 9850 2.50GHz Black Edition (Socket AM2) - Retail
The AMD Phenom processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance.
AMD releases the new AMD Phenom™ 9850 Black Edition quad-core processor with Clock Multiplier Control for tunable performance. The newest Black Edition processor can improve platform performance by unlocking the potential of AMD OverDrive™– the industry’s most powerful Windows-based performance tuning utility.
- True Quad-core Desktop Processor
- Unlocked Multiplier for the ultimate overclocking flexibility
- 2.50GHz clock speed
- 2MB L2 cache
- 2MB L3 cache
- DDR2-1066 support
- 65nm process technology
- Integrated Memory Controller
- Fast Hypertransport 3.0 technology
- Cool & Quiet v2.0
- Heatsink & Fan included
Price: £131.99+VAT (£155.09 inc VAT)
BUY NOW!
XFX GeForce 8800 GTX Extreme 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
the 8800 series is the world's first directx 10 graphics card with full shader model 4.0 support. it delivers unparalleled levels of graphics realism and film-quality effects. even more, it also supports the nvidia lumenex™ engine to give unsurpassed image quality, floating point accuracy, and fast frame rates. built for windows vista™, the 8800 series ensures the best possible performance when running the windows vista 3d graphical user interface. the 8800 series complies with many cutting-edge xtreme-hd features. it provides two dual-link dvi connections to support two hi-end, ultra-large, 30-inch lcd monitors at a mind bending 2560x1600 resolution. with an embedded revolutionary hdtv encoder, the 8800 series also supports crystal clear hdtv output up to 1080i. on top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as mpeg-2, wmv, wmv hd with nvidia exclusive purevideo™ hd technology. what's more, playback of hd dvd, blu-ray disc, and other protected content at full hd resolutions with integrated high-bandwidth digital content protection (hdcp) is fully supported. the winfast® px8800 series complies with many cutting-edge xtreme-hd features. it provides two dual-link dvi connections to support two hi-end, ultra-large, 30-inch lcd monitors at a mind bending 2560x1600 resolution. with an embedded revolutionary hdtv encoder, the 8800 series also supports crystal clear hdtv output up to 1080i. on top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as mpeg-2, wmv, wmv hd with nvidia exclusive purevideo™ hd technology. what's more, playback of hd dvd, blu-ray disc, and other protected content at full hd resolutions with integrated high-bandwidth digital content protection (hdcp) is fully supported.
- geforce 8800 gtx core running at 600mhz
- shader clock speed of 1350mhz
- 768mb gddr3 memory running at 1900mhz
- 384-bit memory interface
- 128 stream processors
- shader model 4.0
- texture fill rate: 36.8 billion/sec
- memory bandwidth: 86.4gb/s
- designed for extreme hd gaming
- nvidia pure video technology
- dedicated video processors free the gpu shaders to run 3d applications
- dual dual-link dvi supports two 2560 x 1600 resolution displays
- hdcp enabled!!
- sli ready – upto 2x the performance of a single gpu (available on with future driver release)
- true high dynamic range rendering support – based on open exr technology
- world's first unified architecture supporting microsoft® directx® 10
- built for microsoft® windows® vista™
- supplied with company of heroes (dx10 version) full pc-game
- 2yr warranty with ocuk direct (for xfx warranty contact ocuk for rma and we will endeavour to resolve your problem within 7 working days)
note: this card is 275mm in length so make sure it fits in your case! also the cards require pci-e x16 slots, they will not function in a x8 slot so for sli you need dual x16 mainboard. finally 500w minimum for psu and 600w+ is recommended.
price: £154.99+vat (£182.11 inc vat)
buy now!
gainward geforce 9800 gtx 512mb gddr3 tv-out/dual dvi (pci-express) - retail
the gainward nvidia® geforce® 9800 gtx 512mb graphics card raises the performance bar by enabling full-throttle lifelike game play at intense resolutions while providing optimal power management with hybridpower™ technology. the purevideo® hd engine delivers unmatched video and movie quality with spectacular picture clarity featuring scene-optimized color and contrast enhancement. and when coupled with nforce® sli®-ready motherboards, provides amplified performance up to 2x in a dual sli configuration and up to 2.8x in 3-way sli* mode. packing more performance at an exceptional value, the gainward nvidia® geforce® 9800 gtx 512mb graphics card offers extreme hd gaming and a first-class entertainment experience.
- geforce 9800 gtx core running at 675mhz
- shader clock speed of 1688mhz
- 512mb gddr3 memory running at 2200mhz
- 256-bit memory interface
- shader model 4.0
- full-throttle gaming at extreme hd resolutions and support for 3-way nvidiar slir mode
- full microsoftr directxr 10, shader model 4.0 and pci expressr 2.0 support
- hdcp enabled!!
price: £164.99+vat (£193.86 inc vat)
buy now!
his ati radeon hd 3870 x2 1024mb gddr3 tv-out/dual dvi/hdmi (pci-express) - retail
advance to ultimate hd gaming with incredible performance, life-like graphics and support for microsoft® directx® 10.1. with dual ati radeon™ hd 3870 gpus working in exquisite precision, you’re ready to dominate the battlefield from over one teraflops of gpu compute power. and thanks to plug-and-play ati crossfirex™ upgradeability, you can scale your performance to even greater heights. ati powerplay™ technology first used in ati mobility radeon™ notebook gpus has been built into the ati radeon™ 3800 series gpu. this exciting break-through technology delivers further on amd’s commitment to reducing the energy consumption in computing technologies. the technology is designed to enable power saving profiles that help reduce power consumption when the gpu is idle or in minimal use in comparison to previous products. this dynamic power management enables the gpu to automatically adjust power between low, medium and high states. it can alter the engine and memory clocks, as well as the voltages based on the software application’s activity level. connect your pc to your home theater and start watching hd content from your computer using new ati radeon™ hd 3800 series graphics cards. the ati radeon™ hd 3800 series is designed to decode and playback blu-ray™ and hd dvd formats using dedicated hardware within the gpu. this technology, known as uvd or unified video decoding, is part of ati avivo™ hd, the new collection of technologies that are designed to improve the visual and connectivity capabilities of ati radeon™ hd 3800 series gpus. uvd offloads the intensive process of hd video decoding and playback from the cpu while improving the visual quality. this means you can get smooth, high quality hd video playback from entry level pcs or free up the cpu for other tasks while you enjoy the movie. and with hdcp built into the gpu, the new cards easily enable playback of protected content. the ati radeon™ hd 3800 series gpu further enhances the hd entertainment experience by making it easy to make the connection to a big- screen or home theater system. with built-in 5.1 surround audio (ac3) pass-through capabilities, the new gpus and graphics cards support a single hdmi connection direct to a compatible tv or receiver. this single cable carries both the hd video and 5.1 surround audio for a clean, high definition connection. some graphics cards will have an hdmi connector built in, while others will use a special ati radeon dvi-i to hdmi adapter. these options mean greater choice and flexibility for consumers when connecting to pc monitors or home theaters for maximum enjoyment of full hd 1080p content. new ati crossfirex™ multi-gpu technology takes your gaming experience to the next level with more scalability, performance and compatibility. the technology combines the awe-inspiring capabilities of multiple ati radeon™ graphics cards and an ati crossfirex ready motherboard to meet the hard-core demands of your alternate reality. new ati radeon™ hd graphics cards are designed with an internal ati crossfirex™ bridge interconnect system to simplify installation. experience stunning visual realism in today’s demanding 3d games with uncompromising image quality, especially on hd displays. ati crossfirex: multiply and conquer!
- dual-gpu technology – don’t fear cranking up the settings - with dual ati radeon™
battlefield.
- over 1 teraflops of gpu compute power - 640 stream processors (320 x 2) deliver
the raw horsepower to attack the most demanding graphics applications.
- incredible performance – you’ll be blown away by life-like graphics from the latest
microsoft® directx® 10.1 games, with stunning 3d graphics and shading effects.
- ati crossfirex™ – scale your 3d performance to greater heights quickly and easily with
plug-and-play ati crossfirex technology that supports up to four gpus.
- more processing performance per watt – the ati radeon™ hd 3800 series
- gpus deliver up to twice the gigaflops per watt of previous generations of amd gpus.
- 2 x ati radeon r680 cores running at 825mhz
- 1024mb gddr3 memory running at 1800mhz
- 640 (320 x2) stream processing units
- superscalar unified shader architecture
- 2 x 256-bit memory interfaces
- directx® 10.1 / shader model 4.1 support
- dynamic geometry acceleration
- game physics processing capability
- ati crossfirex™ multi-gpu support for highly scalable performance
- use up to four gpus with an amd 790fx based motherboard
- high-speed 128-bit hdr (high dynamic range) rendering
- up to 24x custom filter anti-aliasing
- ati avivo™ hd video and display technology*
- built-in hdmi and 5.1 surround audio
- support for the ati radeon™ dvi to hdmi adapter
- unified video decoder (uvd) for blu-ray™ and hd dvd
- ati powerplay™ energy conserving technology
- 55nm process technology
- ati avivo™ hd is a technology platform
£199.99+vat (£234.99 inc vat)
buy now!
bfg geforce 9800 gx2 1024mb gddr3 tv-out/dual dvi/hdmi (pci-express) - retail
beautifully designed and engineered for extreme power, the bfg nvidia® geforce® 9800 gx2 1gb graphics card is the console within - a complete, high definition entertainment and gaming solution for the pc. with nvidia hybridpower™ technology and two on-board gpu's, the bfg nvidia® geforce® 9800 gx2 is bar-none the fastest graphics card available and up to 50% faster than geforce® 8800 ultra. when paired with an additional bfg nvidia® geforce® 9800 gx2-based graphics card and an nvidia nforce® 7 series motherboard, this quad nvidia sli® technology solution creates the most awe-inspiring, screaming fast gaming platform to date. be blown away by scorching frame rates, true-to-life extreme hd gaming, a picture-perfect hd dvd and blu-ray disc® movies with ultra-smooth playback.
- geforce 9800 gx2 core running at 600mhz
- shader clock speed of 1500mhz
- 1024mb gddr3 memory running at 2000mhz
- 512-bit memory interface
- 256 stream processors
- shader model 4.0
- texture fill rate: 76.8 billion/sec
- memory bandwidth: 128gb/s
- up to 50% faster than geforcer 8800 ultra
- display connectors: 2 dual-link dvi-i, hdmir out
- hdcp capable, hdmir capable
- hdcp enabled!!
- sli ready
- lifetime manufacturer warranty (contact bfg representative on 001 866 234 3499 for warranty services)
- 24/7 email manufacturer support (http://www.bfgtech.com/tech_redux.html)
Note: This card is 295mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 600W minimum for PSU and 700W+ is recommended. Also make sure your PSU has true 8 pin PCI-Express connector rather than a 6+2 pin connector.
Price: £299.99+VAT (£352.49 inc VAT)
BUY NOW!
BenQ FP241VW 24" Widescreen Ultimate Gaming HDMI/HDCP LCD HD Monitor - Silver/Black
Get into all the action in widescreen with BenQ's latest professional gaming LCD monitor. This 24-inch beauty features the latest leading technology – you'll experience smooth, lifelike visuals that meet even the most demanding standards of all avid gamers. For the adrenaline-pumping ride of your life, look no further than the BenQ FP241VW. Made purely for hardcore gamers, the FP241VW is simply unique, sleek and stylish. Surrounded with a premium metallic frame, the impressive 24” widescreen is tilt adjustable – ensuring that you find that elusive perfect viewing point for pole position. The elegant outer frame also provides space to hang headphones, game controllers and place figurines on top. Expect all your games to be smooth, crisp and unbelievably clear with BenQ's new 24-inch FP241VW and 19-inch FP94VW. With just a simple touch of a button, six specialized display modes (Standard, Dynamic, Movies, Photos, Action Game and Racing Game) deliver the widest range of viewing experiences. The two dedicated gaming modes – Action Game and Racing Game – give you the power to configure mind-blowing gaming experiences, taking you into the heart of the game. On top of that, the FP241VW is integrated with PerfectMotion dynamic video processing technology. It uses two steps to ensure that frustrating, game-inhibiting ghosting and motion blur around the screen edges are eliminated. Firstly, it reduces the grey-to-grey response time, and secondly, it inserts a black frame between motion frames – giving you a crystal-clear view, ultra-smooth motion and sure-fire advantage over the competition. Working together with an ultra-fast 12ms MPRT (Motion Picture Response Time), smooth playback of even the most action-packed visual contents is assured – satisfying your expectations of the best possible viewing experience. BenQ's exclusive Senseye Technology features in both the FP241VW and the FP94VW. Image quality is automatically and dynamically improved to deliver exquisite clarity that's bolder and brighter – taking you into the action so you don't miss anything. The human eye is emulated by fine-tuning the colour, clarity, motion and contrast – effectively enhancing image signals to display them perfectly. So, whether you're racing to win, defeating the enemy or living out a fantasy, the unsurpassed visual quality is a true force to be reckoned with. Live the action with the FP241VW's superior, lifelike, high-definition images. Thanks to its 1920x1200 (WUXGA) resolution and HDMI (High-Definition Multi-media Interface), it fully supports video resolutions of 1080P (Native Full HD 1920x1080). You'll see details you never knew existed with the perfect picture every time. HDMI is a new generation connector and is simply the best for digital video and audio performance. It allows easy connection of HD enabled equipment such as HD DVD players, the latest gaming consoles and online games. All this is done by carrying both digital video and audio signals via one cable. It couldn't be easier.
- Now supports 1:1 Pixel Mapping
- Exclusive PerfectMotion Technology
- Full HD Support (1080p)
- HDMI Interface
- PIP (Picture-in-Picture)
- senseye technology!
- Full pivot, swivel and height adjustment
- Built in USB Hub (3 Ports)
- 1920 x 1200 (WUXGA) Optimum Resolution
- 16.7 Million Colours
- 1000:1 Contrast Ratio
- 6ms Response Time
- 500 cd/m2 Brightness
- Viewing angle: 178/178
- One DVI-D Input
- One Analogue Input
- One S-Video Input
- One Composite component Input
- One HDMI Input
- Warranty : 3 year on-site warranty supplied by Manufacturer
Price: £414.99+VAT (£487.61 inc VAT)
BUY NOW!
Now get your wallets out!! :D :D
