It doesn't help that requirements are set so high and trainee level opportunities literally don't exist. At all. You could have a masters in computer science, few companies would touch you with a half decent wage without a couple of years commercial experience.
Not really, I didn't particularly work that hard and ended up with a 1st class CS degree and a summer placement at IBM. Apart from a few personal coding projects that's all the experience I have, not a couple of years. If you can demonstrate a proper passion for the area and your not just in it for the money then its no problem. I applied for 5 jobs, got accepted on 3 of them and took the best one. I start on 24k which is pretty low, but after a few years I was told I would be on 30k+ no problem. There's graduate jobs out there which start on 28k~ ish.
