- 7 Mar 2005
- LU7
What as in going to win the title in the same season as spinning off more than anyone in history?
Wanna take this to MSN?
Stop the press, who is that?
I've been sitting here a while looking at that but i still can't figure out what it's a picture of![]()
Images No Larger Than 800x600- DaveMac
what calendar is that?
I think Vista Glazz only patches the system files and also allows you to prevent the taskbar from going opaque when a window is maximized. To get the fully transparent taskbar you need to download a separate theme which has high levels of transparency. I'm not sure on which ones have this but here might be a good place to startshaffaaf27 said:how does one make the start menu fully transparent?
vistglazz dont work for it.
Ultramon?roflcakes22 said:It's called Rainlendar ...
Can anyone tell me what the name of that app is that some of you use on here for dual displays that gives you quite some good tweaks etc ... i've had a look through about 20 pages but dont fancy looking through short of 200 lol
Rainlendar. http://www.rainlendar.net/cms/index.phpwhat calendar is that?
