Build advice, Base Unit + 24" Monitor for £750?
27 Nov 2007
Manchester
hey guys
Can I do it? Can I buy a base unit and a nice 24" monitor for £750? Can I build a base unit that will run COD4 on all high, with a good FPS, at the 24" native res?
I need to buy;
Case
PSU
Mobo
Memory - only 2GB needed as will be running XP
Graphics Card
CPU + Aftermarket HS + Paste
Hard Drive
DVD Drive
24" Monitor
I have a sound card, speakers, mouse, keyboard, OS etc.
Can it be done for a total of £750 all in? Inc. delivery etc.? Not afraid to over clock the CPU etc.
Cheers
Not the best cpu, but It can always be upgraded to a quad later.
Could save a little by getting a cheaper motherbaord, and a cheaper case, akasa zen is only £27 TWO...
NINJA EDIT: EXACLTY the same price as AcidHell2 :o
Many thanks for your suggestions guys, it's nice to know if can be done!
Also, I'l be using XP for the time being, so won't need the 4GB ram, 2 will suffice, then when I upgrade to vista I can just buy another 2.
cheers
[IM]http://i172.photobucket.com/albums/w31/viper1405/750.jpg[MG]
Just spotted that :D..
The ocuk screen is not HDCP enabled so if you upgrade to bluray dvd later it won't play. Unless you remove the copyright. I think some players will play it with copyright removed, but something to think about.
cheers
not much point tbh, the price difference is not worth it. Unless you have to get it under 750.
So, acid, what you're saying is that if I wanted to connect to an xbox 360, ps3, blu-ray it would need to be HDCP compliant to work? What does HDCP do/mean?
