Wifes Arosa has started to play up since it found out it was up for sale.
Had to replace the coil pack today and it revs fine but it's quite lumpy at tickover, seems to be down around 550-650rpm according to the rev counter. Once you give it a bit of throttle (up to around 900rpm guestimate) everything smooths out.
So logically i should just turn up the tickover and make the problem go away....
Only i can't find the throttlestop.
I've taken the huge plastic cover off the top of the engine and i recognise which bit in the oil cap and that's about it. Sensors, wires, funny looking vent/valve things, pipes, plastic, but that's it. Nothing i actually recognise as an engine part.
Does this thing even have a throttlestop? Is it fly-by-wire? Or am i just being blind?
Cheers
Cheers
