disconnect your battery and leave for 10 mins then reconnect and let the car idle for around 5 mins so the throttle body re-calibrates. dont hit the accelerator pedal in this time. You might as well give the throttle body a clean before doing this, carb cleaner is good for that
Have you changed spark plugs and HT leads? That would have been my first stop before the coil pack to be honest.
... easy to spot since you usually get starting issues.
Mine doesn't work like that, you have to perform a manual throttle adaption, with this also being VAG i'd imagine it to be the same.
Infact if you disconnect the battery the ecu with lose its adaption settings forcing a manual adaption, easy to spot since you usually get starting issues.
pulled each HT lead while it was running and the tickover went to hell so each cylinder is doing something.
Next it's a set of leads for 20 quid. Which didn't fit. Turns out the small plugs need funny metal ended leads. At 45 quid a set![]()
