- 29 Jun 2004
Okay, here's my space restriction:
520mm / 22 inches wide
510mm /20 inches high
That's the abbsolute size I can reach! Now i've looked at 20" monitors they're small enough to fit in the dimensions above.
I've looked at 22" some can fit in the hole above!
I was looking at the Belinea o.display 22" Widescreen LCD Monitor however it doesn't have any user reviews.
I'm looking at £200 and to be honest, will be definately buying tomarrow or tuesday.
What I want is the ability to hook up a Playstation 3 or X-Box 360 too please as well as PC gaming and general surfing.
To give you an idea of how bad things really are, i've never had a TFT monitor, and i'm typing away on a fat ******* 17" CRT monitor that's 8 years old!
Thanks guys!
Thanks guys!
