Dirtydog you need to experience Visual Studio crashing on an XP machine with 2GB memoryThe pain
Sometimes I go and make a cuppa...!
Is 2GB not enough for its demands?!Dirtydog you need to experience Visual Studio crashing on an XP machine with 2GB memoryThe pain
XP x64 and Server 2003 x64 aren't consumer OSes. Driver support is also poor in comparison to Vista x64 (although admittedly it seems to have improved since Vista x64 came out...)
At work I've been running Visual Studio and SQL on a machine with 512mb and XP for the past 3 yrs. Was as stable as a rock. Only problems was it was a little slow. We've now upgraded the same machines to 4GB of ram and there was a big speed improvement. No issues with stability though.
At home I'm running Visual Studio on Vista 32 and now 64 and tbh I haven't noticed any difference in stability. TBH its a pain getting everything working on Vista as you need patches, different version of Studio and SQL and IIs etc.
I'd really like to get Server 2008 up and running as a workstation. As it was really a lot faster.
Did I just get hugely lucky with XP x64 then? I've never had a single driver issue with it - all the hardware inside my box works, my wireless adapter works, my USB TV card works, my printer/scanner/copier/kitchen sink works....
Obviously people must have had problems with it for it to gain the "crappy drivers" reputation it has, but I've never come across a single problem with it.
Even firefox crashing requires explorer to restart. Explorer restarting is the norm. Xp closing just the crashed app is not the norm. Unless you can kill the process in manager.
your machine sounds flaky mate. I suspect issues beyond the fault of XP itself.your machine sounds flaky mate. I suspect issues beyond the fault of XP itself.
Must be PEBKAC then![]()
You've never had VS crash then? Never got the WinForms designer into a pickle or anything??
I only have one problem with vista and it is a big one. Is slow file copying and this doesn't apply to everyone using vista.
I think you will find that PEBKAC applies to IT Pro's too. No offence to those whom take their job seriously but in most IT departments the world over it takes the average Joe like me and you to sort out the problems of others and find solutions from MS....It is about time MS gave us the users more credit for bringing issues to light and helping with the solution. And not rewarding the hypocrites whom call themselves IT Pro's who live in their own little world cocooned from the real working environments around them.
Walking into Somewhere like PC World and ask them a few questions about Vista and I bet they draw a blank apart from the fact that they sell it. Their famous technical department is full of pc's running XP and it will cost an arm and a leg for technical advice you can get here for free....
The 32 bit age is practically over apart from the Bios restrictions....
...This my friends is where the problem lies. we have a good operating system but because there are some lazy programmers out there we don't get the support for 64 bit as we should because around 86% of pc owners are still using a 32 bit Operating system. ...
The only reason why 2 PCs on the LAN are 32Bit Vista is that a friend sold me business 32 for cheap as chips and then when it failed to play DVDs, my mummy bought me Premium for xmas last year and I just didnt want to waste them.
