http://www.griffintechnology.com/products/powermate
iDrive pie dish?
Is there such thing as a single DIN flip out screen with toutch screen and a DVD drive? I can find DVD players which fit the bill, but nothing for a car PC.
How long does it take to boot up mate?
Looks good easy, did you consider using a Compact Flash to IDE, or SSD for the hard disk?
Although hope the laptop is well secured as I don't think the wires will quite keep it in place
Could you not hide it somewhere at the side of the boot?Nice installationAlthough hope the laptop is well secured as I don't think the wires will quite keep it in place
Here are some pics:
I wanted to be able to remove the screen at will for security reasons.I used a locking clip like you see in the pics
[TW]Fox;11545114 said:That looks absolutely horrible - you've blocked your aircon vents and it makes the interior look really nasty
You've also blocked the adjuster dial on the heater with your clip, how do you adjust the top vent temp now?
I agree with the Fox, it looks absolutely awful![]()
I agree that it looks turd
Should have fit it INTO the dash tbh.
