Can I assume this will clock well since you can buy LN2 pots with it!?
Isn't FOXCONN owned by Asus?
Thanks. I've got my wires crossed (as usual).Thats Asusrock (or Asrock).
For some reason people over at XS do not like Foxccon, and some say that Foxccon tech support is very bad and they don't want to talk "overclocking" even tho this board is supposed to be an oveclockers tool.
They also mention about Foxccon refusing honoring any warranty if you use the boards other than "retail".
I assume an "ethusiasts" board with a huge price tag should have some sort of overvolting tolerance and the manufacturer should be confident enough to apply a few years warranty on it.
Are they DDR3 or DDR2?
