But how they can be different if the amounts of drugs in them are exactly the same? Obviously if you buy two kinds of painkiller and the branded one contains more paracetamol then it'll be more effective...
You can?
Unless their dangerous.
https://www.sigmaaldrich.com/catalog/search/ProductDetail/SIAL/A7085
51,70 euros for 100 grams of analytical grade acetaminophen (cheaper if you get one of the lower purities.)
Just be sure to buy an accurate set of calibrated scales.
Heh, never seen websites like that before. Though I would imagine they don't sell some pharmacy only stuff like dihydrocodeine.
best ones are the paracetamol and codeine ones.
Also if you've only tried paracetamol try aspirin, although don't use it all the time.
I don't think you should be recommending the use of codine, it's a hardcore painkiller and can be addictive too.
http://en.wikipedia.org/wiki/Codine
You can get 99% pure morphine off there with the right forms etc.
The principle one being a Home Office licence to possess controlled drugs, as morphine is Class A.
M
Purchasing 190- and 200-proof ethanol has never been easy, until now! Because these ethanols are federally regulated, an ATF permit is required to purchase 190- and 200-proof ethanol. Sigma-Aldrich takes the hassle out of this process for you. No ATF paperwork is needed, nor any records for you to keep. Sigma-Aldrich immediately pays the federal excise tax (200-proof pure alcohol=$27.00/gallon).
Doses are so small without prescription it's not very risky at all, also they contain such a high doe of paracetamol you would vomit it all back up if you tried to take enough to get an effective high from the codeine.
It was on the tv a while ago and they are exactly the same. The main reason that the brand name ones are more expensive is because they need the money to cover there r + d costs.
if the ingredients are the same then there is absolutely no difference and you should get the cheapest.
I would expect the big companies to have better quality control then the cheaper brands. Also there is the psychological effect, if you think the big companies produce better/more potent drugs then the smaller companies, then when you take the drugs, your brain may make the big name drugs seem to work better, even though its all in your head.
If the objective is to get high though, people would extract the codeine first as it does not require any special equipment, it only requires purchasing the tablets from multiple different stores to get enough tablets to produce a usefull ammount of codeine.
Of course, if you intend to use it as intended then chances are there will be no problems at all.
Try "Class C controlled drug" except in certain circumstances.
M
yup.
Need to find out what you need to get the duty free ethanol, then a way to forge it
edit: wish i lived in the USA![]()
i get duty free ethanol - its about £5 for 2 litres (99.99% pure)
and no, you're not having any![]()
