The Reviews show the 790I Mobo does not like CAS 7, and advises CAS 8.
you just can't stop helping! thanks!
So do I just change the 7-7-7-20 to 8-7-7-20?
thanks.
thanks.
I'm running an S2E with 2GB OCZ Platinum 1333Mhz DDR3 7-7-7-20 and have no problems whatsoever. Have you run memtest yet?
I'd ask the place you bought it from for a upgradeto a EVGA 790i
the board's fine, its just the memory! all the 790i's are pretty much the same, apart from Asus' shoddy tech support!![]()
Get rid of the Striker II board, its a POS, like all of the Nfail intel range of boards.
