Hello guys, thanks for helping out.
Ok. I have up to £500 to spend on a monitor. Its primary use will be for PC use and Xbox 360.
I have a DVI connection for my PC and my 360 uses Component (Red Green Blue) although i have the VGA cable..
I do need the monitor to have both these connections as i really dont want to use VGA for the 360.
The size i require is either 22" - 26", 24" would be ideal but im open to suggestions.
Resoloution wise i would preferably like it to be 1920x1080 or (1200).
The monitor has to have superb picture quality and look awesome for both machines. I do a lot of gaming on the PC and of course on the 360, so the quicker response time the better.
Help me out and thanks for your time.
[[EDIT]]--- Sorry for being a pratt, mods please move it to the correct forum. Sorry
(a 1080P one though, you're right that 720P is too low res for close viewing, would look bad)
